How can i know what assembly components are positioned behind a given plane???
HI everyone!
How can i know what assembly components are positioned behind a given plane.
Anyone have ideas on how to do this?
thanks.
The first thing that comes into my mind is create a reference solid covering all objects behind the plane, and then check interference of the complete assembly with this solid... Hope that helped
ekinsb
This is an interesting problem.  Can you provide a little more detail about exactly what it is you need?
Brian Ekins
Mod the Machine blog
I Want to identify all the assembly components that are positioned behind or in the front of a given plane.
once i have those components i will be able to supress them and create a level of detail, in this way i dont have to select components one by one in large assemblys.  and i'm  saving a lot of time.
thanks.
