How can i get the ilogic rule to display "1 1/2"=1'0" in the drawing view, when I update a views dimensions per ilogic form?
rkeeleyS5869
rkeeleyS5869
I'm trying to create an ilogic code that updates the size of the view based on the length x width and height of an object. I was able to successfully update the size of the drawing view, but since Inventor's ilogic scales per decimals, it shows up as an arbitrary fraction. Ex: .25 scale factor = 1/8 on the drawing sheet. I would test to say 1 1/2" = 1'-0". Can someone help with getting that to work?
C_Haines_ENG
Its a simple solution, but I hate it:
EDIT: I missed the point of this question, can you reword your problem?
Sub Main
	Dim oValue As Double = InputBox("Enter Decimal Value", "Decimal To Fraction", "0.00")
	' THIS LIST CONTAINS ALL OF THE "FRACTION" VALUES YOU WANT TO CHECK FOR
	Dim oFractions As New List(Of Integer)
	oFractions.AddRange({2, 4, 8, 16})
	'CALLING FIND FRACTION FUNCTION
	Dim oFractionValue As String = FindFraction(oValue, oFractions)
	MsgBox(oFractionValue)
End Sub
Function FindFraction(oDecimal As Double, oFractions As List(Of Integer))
	'ROUND THE VALUE TO THE NEAREST MAX FRACTION VALUE
	Dim oValueRounded As Double = Round(oDecimal * oFractions.Max) / oFractions.Max
	'CHECK IF VALUE IS JUST A WHOLE NUMBER, IN WHICH THIS ISNT NEEDED
	If oValueRounded = Int(oValueRounded) Then Return oValueRounded
	'GET JUST THE DECIMALS FROM THE VALUE
	Dim oDecimals As Double = oValueRounded - Int(oValueRounded)
	'LOOP THROUGH EACH DENOMINIATOR
	For Each oDenom As Integer In oFractions
		'GO THROUGH EACH VALUE IN THAT DENOMINATOR (CURSED)
		For i = 1 To oDenom - 1
			'IF THE DECIMAL VALUE MATCHES THE FRACTION, RETURN IT
			If oDecimals = i / oDenom Then Return Int(oValueRounded) & " " & i & "/" & oDenom & Chr(34)
		Next
	Next
End Function
