How can I get a Section Plan with multiple Sketch in Section with C# Inventor Api Or VBA?
nebi_guler
nebi_guler
As seen in the screenshot, the first Sketch created is taken as a reference and the SectionPlan operation is performed on only one Sketch. How can I write to include other Sketches? I know there is a small setting but I couldn't find it.
nebi_guler
Thank you so much @Gabriel_Watson I will check it
nebi_guler
Thank you again . I know these posts. I did look again maybe just in case I'm missing a few things but it doesn't solve my problem. There is a missing setting, I couldn't find it. I'm trying to get a SectionPlan using multiple Sketch.
Michael.Navara
As described here it is not possible to use multiple sketches for single SectionDrawingView definition. You need to create new sketch and re-draw entities from others to this new one.  DrawingSketch.AddByProjectingEntity Method can't be used for sketch entities.
nebi_guler
DrawingSketch oDrawingSketch;
oDrawingSketch = viewExterior.Sketches.Add();
oDrawingSketch.Edit();
Point2d oPoint = _repositoryBase.ReturnTransientGeometry().CreatePoint2d(sp.SectionPlanPoint.X, sp.SectionPlanPoint.Y);
SketchLine oSketchLine = null;
foreach (var item in sp.SectionPlanPoints)
Point2d oPointOne = _repositoryBase.ReturnTransientGeometry().CreatePoint2d(item.SectionPlanSketchStartPoint.X, item.SectionPlanSketchStartPoint.Y);
Point2d oPointTwo = _repositoryBase.ReturnTransientGeometry().CreatePoint2d(item.SectionPlanSketchEndPoint.X, item.SectionPlanSketchEndPoint.Y);
if (oSketchLine == null)
oSketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oPointOne, oPointTwo);
else
oSketchLine.Parent.SketchLines.AddByTwoPoints(oPointOne, oPointTwo);
@Michael.Navara The method I use now is
nebi_guler
     else
         SketchLine SketchLineMerge = oDrawingSketch.SketchLines.AddByTwoPoints(oPointOne, oPointTwo);
         oSketchLine.EndSketchPoint.Merge(SketchLineMerge.StartSketchPoint);
         oSketchLine = SketchLineMerge;
