How can I change this so that it's reading as a string?
chris
Advisor Advisor
chris
I have a small snippet of iLogic, however, I am getting an error on line 4 with the two parameters after the "=" about them not being a string... not sure how to fix it
If FcType = "FLAT FACE" Then
	Parameter("d0") = "Base_O"
	Parameter("d4") = "Base_T" - "Face_Off"
Else If FcType = "RAISED FACE" Then
	Parameter("d0") = "Base_R"
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
Curtis_Waguespack
Hi @chris
Assuming that Base_T is a variable defined in your code you can just remove the quotes enclosing the name.
	Parameter("d0") = Base_O
	Parameter("d4") = Base_T - Face_Off
	Parameter("d0") = Base_R
chris
oh... lol... figured I'd miss something so simple, Thank you, I have no idea why I had quotes around any of those... where is the "hit myself in the forehead" emoji
