How can I arrange multiple drawing sheets in order of item number?
ksmYFC8W
ksmYFC8W
항목 번호 순서대로 여러 드로잉 시트를 정렬하려면 어떻게 해야 합니까?
Here is a topic, where sheets are ordered by name. Is that what you want?
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-sort-sheets-by-sheet-name-in-ope...
WCrihfield
@ksmYFC8W
What do you mean by 'item numbers'?
Do you mean the integer after the colon (:) at the end of each sheet's browser node name?
Do you mean there is a PartsList somewhere in the drawing and there is only one sheet within the drawing for each item in the PartsList, and you want the sheets ordered by what Item is being shown on within the first view of each sheet?
Wesley Crihfield
(Not an Autodesk Employee)
