How can I annotate these dimensions in a drawing, using iLogic?
ricardo_cano2
ricardo_cano2
Hi all, hopefully I'm not asking something that has been answered dozens of time before 🙏🙏🙏
I'm trying to create an iLogic rule for drawings.
Where annotations are automatically added in an organized manner, and where holes exist, the annotation is added to the dimension.
Public Sub Main()
  Dim oDrawDoc As DrawingDocument
  oDrawDoc = ThisApplication.ActiveDocument
  Dim oActiveSheet As Sheet
  oActiveSheet = oDrawDoc.ActiveSheet
  Dim oDrawingCurveSegment As DrawingCurveSegment
  oDrawingCurveSegment = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Seleccionar la línea del origen")
  Dim oDrawingCurve As DrawingCurve
  oDrawingCurve = oDrawingCurveSegment.Parent
  If Not oDrawingCurve.CurveType = kLineSegmentCurve Then
    MsgBox("Esta no es una línea Ingeniero")
    Exit Sub
  Dim oDimIntent As GeometryIntent
  oDimIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kEndPointIntent)
  Dim oDrawingView As DrawingView
  oDrawingView = oDrawingCurve.Parent
  If Not oDrawingView.HasOriginIndicator Then
    oDrawingView.CreateOriginIndicator(oDimIntent)
  Dim oOrdinateDimensions As OrdinateDimensions
  oOrdinateDimensions = oActiveSheet.DrawingDimensions.OrdinateDimensions
  Dim oTextOrigin As Point2d
  Dim DimType As DimensionTypeEnum
  DimType = kHorizontalDimensionType
  Dim TG As TransientGeometry
  TG = ThisApplication.TransientGeometry
  oTextOrigin = TG.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.StartPoint.Y)
  Call oOrdinateDimensions.Add(oDimIntent, oTextOrigin, DimType)
  Dim oIntent As GeometryIntent
  Dim textPt As Point2d
  For Each oDrawingCurve In oDrawingView.DrawingCurves
    Select Case oDrawingCurve.CurveType
      Case kCircleCurve
        oIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kCenterPointIntent)
        textPt = TG.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.CenterPoint.Y)
      Case kLineSegmentCurve
        oIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kStartPointIntent)
        textPt = TG.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.StartPoint.Y)
      Case kCircularArcCurve
        oIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kEndPointIntent)
        textPt = TG.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.EndPoint.Y)
      Case Else
        oIntent = Nothing
    End Select
    If Not oIntent Is Nothing Then
      Call oOrdinateDimensions.Add(oIntent, textPt, DimType)
  Next
  oDrawingCurveSegment = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Select end line to complete ordinate dimension")
    MsgBox("A linear curve should be selected for this sample.")
    Exit Sub
End Sub
This is the code I currently have and the following photo is of the results it generates for me.
best regards, thanks
JelteDeJong
I have a blog post: "Automatically generate hole position dimensions". I expect that it is what you want to do.
There are also other rules for adding other kinds of dimensions on my blog.
Jelte de Jong
Blog: hjalte.nl - github.com
ricardo_cano2
Hola Jelte Jong.
En primer lugar, estoy emocionado. No pensé que alguna vez responderías a mis preguntas en este foro.
He estado leyendo tu blog y creo que es genial.
Estoy creando un guión maestro, pero he progresado tanto que me siento perdido.
¿Puedes darme alguna orientación?
Gracias.
ricardo_cano2
Hi Jelte Jong.
First of all, I'm excited. I didn't think you'd ever be answering my questions on this forum.
I've been reading your blog and I think it's great.
I'm creating a master script, but I've made so much progress that I feel lost.
Can you give me some guidance?
Thanks.
JelteDeJong
Long master scripts can quickly become overwhelming and difficult to manage. Here are a few strategies to keep things organised and maintainable:
1. One Rule to Rule Them All
Create a single master rule that calls other, smaller rules. This helps maintain structure and keeps each rule focused and readable.
2. Create an Add-In
If your rules become too complex or contain too many functions, it might be worth developing an Add-In. While this offers more power and flexibility, it does require a deeper dive into .NET development and can be a bit more challenging to set up.
3. Use a DLL for Your Functions
This is a hybrid approach between rules and Add-Ins. You move most of your code into a DLL and call its functions from your iLogic rules. This keeps your rules clean while leveraging the power of external code.
I’ve written about the Add-In and DLL approaches on my blog and GitHub feel free to check them out.
If you have any questions, don’t hesitate to ask here on the forum!
Jelte de Jong
