Hook into Inventor process for progress
NachoShaw
Advisor Advisor
NachoShaw
Hey
Is there a way to hook into the inventor process for a progress feedback? Different models have different criteria and i'd like to properly report back instead of adding counters. An inventor model will provide a visual update in the bottom right but can we access that through API to use it ourselves?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
jdasilvaS39UQ
Yes, there is a built in ProgressBar object that will display on the bottom bar.
There is a good example in the API help menu "Using inventor's progress bars API sample"
' 64-bit version
Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As LongLong)
' 32-bit version
'Public Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Public Sub TestDialogProgressBar()
    Dim iStepCount As Long
    iStepCount = 50
    ' Create a new ProgressBar object.
    Dim oProgressBar As ProgressBar
    Set oProgressBar = ThisApplication.CreateProgressBar(False, iStepCount, "Test Progress")
    ' Set the message for the progress bar
    oProgressBar.Message = "Executing some process"
    Dim i As Long
    For i = 1 To iStepCount
        ' Sleep 0.2 sec to simulate some process
        Sleep 200
        oProgressBar.Message = "Executing some process - " & i
        oProgressBar.UpdateProgress
    Next
    ' Terminate the progress bar.
    oProgressBar.Close
End Sub
Public Sub TestStatusBarProgressBar()
    iStepCount = 50
    Set oProgressBar = ThisApplication.CreateProgressBar(True, iStepCount, "Test Progress")
    Dim i As Long
        Sleep 200
    Next
    oProgressBar.Close
End Sub
NachoShaw
Hi
That doesn't hook into a process. I'm looking to see if I can hook in rather that build my own process and post its progress to a progress bar.
Nacho
jdasilvaS39UQ
Ah, sorry I misunderstood. I don't know how to get info from an existing process
