Holes counting and sorting based on diameter.
Ahmed.shawkyXTZHN
Message 1 of 24
Ahmed.shawkyXTZHN
Hello all ,
I have one code to count the number of holes in the whole assembly , but I need to also sort the holes based on the dia.
for example  10 mm = # 100
                        12 mm = # 50
and so on , so can Count the fasteners based on these details.
 holes counting rule .
'To run external rule for all sheet metal parts
Dim aDoc As AssemblyDocument
aDoc = ThisApplication.ActiveDocument
Dim iDoc As Document
For Each iDoc In aDoc.AllReferencedDocuments
If iDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
auto = iLogicVb.Automation
auto.RunExternalRule(iDoc, ”Hole”)
iDoc.Close()
Next
iLogicVb.UpdateWhenDone = True
  thanks in advance.
Accepted solutions (3)
Replies (23)
Message 21 of 24
Jordon.Oldham
Hi
sorry to jack the thread, i tried running the above rule for holes in an assembly but i keep getting 'Error on line 5 in rule: HOLE COUNT, in document: FLR-EF-11R-70-01-GA-A00.iam
Class not registered'
could you advise?
Many thanks
Message 22 of 24
dmitrij.furasovSJTF7
Hi Jhoel,
Is it possible to make some changes in this rule, to count holes in non sheet metal parts?
Thanks!
Message 23 of 24
nowell.colsenXK53F
I found your code for the hole Count. what if the part is not a sheet metal?
Message 24 of 24
Ahmed.shawkyXTZHN
Hi @JhoelForshav  can we update the code that generate the drawing table to be part wise and to come in cutting list so all details will come in one table , thanks.
