HoleFeatures
HoleFeatures
HoleFeatures
I'm having a difficult time trying to add a Thru Hole to an extruded part.
I must add the hole After the part is extruded.
The part is very basic, just a rectangle extruded to a thickness of 1/2"
Here is the Sample Code:
Dim oInventorApp As Object
Set oInventorApp = GetObject(, "Inventor.Application")
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oSketch As PlanarSketch
Set oSketch = oPartCompDef.Sketches.Item(1)
Dim oCenterPoints As ObjectCollection
Set oCenterPoints = oInventorApp.TransientObjects.CreateObjectCollection
oCenterPoints.Add oSketch.SketchPoints.Add(oInventorApp.TransientGeometry.CreatePoint2d(1, 1))
Dim oNewHole As HoleFeature
Set oNewHole = oPartCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oCenterPoints, 2, kPositiveExtentDirection)
VB gives me a "Type Mismatch" error when I Add the new hole definition to variable: oNewHole.
In the VB debugger, the AddDrilledByThroughAllExtent() is shown as having a Data Type of "Integer"
Any help would be greatly appreciated.
Brian
Brian, Since you are creating the sketch point on the sketch consumed by the extrude feature, you will need to share the sketch before you create a hole feature with it. (Use oSketch.Shared = True ). Or, create a new sketch for the hole feature. Sanjay- "Stache" wrote in message news:5718519.1112731842191.JavaMail.jive@jiveforum1.autodesk.com... > I'm having a difficult time trying to add a Thru Hole to an extruded part. > > I must add the hole After the part is extruded. > > The part is very basic, just a rectangle extruded to a thickness of 1/2" > > Here is the Sample Code: > > Dim oInventorApp As Object > > Set oInventorApp = GetObject(, "Inventor.Application") > > Dim oPartCompDef As PartComponentDefinition > Set oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition > > Dim oSketch As PlanarSketch > Set oSketch = oPartCompDef.Sketches.Item(1) > > Dim oCenterPoints As ObjectCollection > Set oCenterPoints = oInventorApp.TransientObjects.CreateObjectCollection > oCenterPoints.Add > oSketch.SketchPoints.Add(oInventorApp.TransientGeometry.CreatePoint2d(1, > 1)) > > Dim oNewHole As HoleFeature > Set oNewHole = > oPartCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oCenterPoints, > 2, kPositiveExtentDirection) > > > VB gives me a "Type Mismatch" error when I Add the new hole definition to > variable: oNewHole. > > In the VB debugger, the AddDrilledByThroughAllExtent() is shown as having > a Data Type of "Integer" > > Any help would be greatly appreciated. > Brian
Thank you very much Sanjay, that solved the problem.
Brian
Is this the complete example code and if it is how do you get it to work?
Should it work in INV8?
wrote in message news:4801344@discussion.autodesk.com...
> oCenterPoints.Add
> Set oNewHole =
variable: oNewHole.
> Brian
