Hole Style - find settings in saved drawings
andrew_canfield
andrew_canfield
A tapped hole note was using this as a hole & note thread:
IN <QTYNOTE> PLACES
DRILL<HDIA> X <HDPT> DEEP
& TAP <THRP> X <THRD> DEEP
But it has now been modified to this:
IN <QTYNOTE> PLACES
DRILL <TDDIA> X <HDPT> DEEP
How do I create code to search for the old hole note style?
I wish I could write code, I read up on it but where do you start?
VBA editor (this is going to be a one off - I hope)
New module? ( in the ApplicationProject? idk)
Find where the drawings are saved.
Look inside each .idw file for code which equals :
IN <QTYNOTE> PLACES
print a list of those files?
How do I do that?
I need to read up on what these mean.. I've seen descriptions would like to see video, vbae.JPG
Thanks for your interest
dgreatice
Try this :
1. Select on Application Project
2. Select Module1
3. At Properties - Module1, rename to HoleNoteFormat
4. Then in this module you copy this code:
Public Sub ChangeFormatHoleNote()
    Dim oDwgDoc As DrawingDocument
    Set oDwgDoc = ThisApplication.ActiveDocument
    Dim oSht As Sheet
    Set oSht = oDwgDoc.ActiveSheet
    Dim oDwgView As DrawingView
    Dim oDwgNote As DrawingNotes
    Dim oHoleThreadNote As HoleThreadNote
    Dim OldThreadNoteFormat As String
    OldThreadNoteFormat = "IN <QuantityNote/> PLACES<Br/>DRILL <HoleProperty HolePropertyID='kHoleDiameterHoleProperty' Precision='2' AlternatePrecision='2' UpperTolerance='0.000000' LowerTolerance='0.000000' ToleranceType='kSymmetricTolerance' TolerancePrecision='2' ToleranceAlternatePrecision='2'></HoleProperty> x <HoleProperty HolePropertyID='kHoleDepthHoleProperty' Precision='2' AlternatePrecision='2' UpperTolerance='0.000000' LowerTolerance='0.000000' ToleranceType='kSymmetricTolerance' TolerancePrecision='2' ToleranceAlternatePrecision='2'></HoleProperty> DEEP<Br/>&amp; TAP <HoleProperty HolePropertyID='kThreadDesignationHoleProperty'></HoleProperty> x <HoleProperty HolePropertyID='kThreadDepthHoleProperty' Precision='2' AlternatePrecision='2' UpperTolerance='0.000000' LowerTolerance='0.000000' ToleranceType='kSymmetricTolerance' TolerancePrecision='2' ToleranceAlternatePrecision='2'></HoleProperty> DEEP"
    Dim NewThreadNoteFormat As String
    NewThreadNoteFormat = "IN <QuantityNote/> PLACES<Br/>DRILL <HoleProperty HolePropertyID='kTapDrillDiameterHoleProperty' ></HoleProperty> x <HoleProperty HolePropertyID='kHoleDepthHoleProperty' ></HoleProperty> DEEP<Br/>&amp; TAP <HoleProperty HolePropertyID='kThreadDesignationHoleProperty'></HoleProperty> x <HoleProperty HolePropertyID='kThreadDepthHoleProperty' ></HoleProperty> DEEP"
For Each oDwgView in oSht.DrawingViews
Set oDwgNote = oSht.DrawingNotes
    For Each oHoleThreadNote In oDwgNote.HoleThreadNotes
        If oHoleThreadNote.FormattedHoleThreadNote = OldThreadNoteFormat Then
            oHoleThreadNote.FormattedHoleThreadNote = NewThreadNoteFormat
        oHoleThreadNote.QuantityDefinition = kNumberOfLikeHolesNormalToView 'or replace with kNumberOfHolesInFeature
        'OldQuantityFormat = oHoleThreadNote.FormattedHoleThreadNote
        'key = InputBox("TEST", "TEST", OldQuantityFormat)
    Next
next
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
andrew_canfield
Many Thanks 🙂
I've tested it on a drawing with the old style & a macro box pops up.
Run on a drawing without the old style & no marco box
Hopefully I've understood the instructions.
Can drawings saved on the hard drive be searched without being opened?
