Highlighting sketch line start and endpoints
I'm trying to highlight a sketched line's startpoint in green and the line's endpoint in red. I don't get an error, but it's not working either - what am I doing wrong?
Set oPartDoc = ThisApplication.ActiveDocument
Set oSketch = fActivateSketch(oPartDoc)
Set oSelect = oPartDoc.SelectSet
Set oStartHLSet = oPartDoc.CreateHighlightSet
Set oEndHLSet = oPartDoc.CreateHighlightSet
Set oRed = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
Set oGreen = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
Set oBlue = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
For Each oEnt In oSelect
If TypeOf oEnt Is SketchLine Then
Set oLine = oEnt
' Get the start and endpoints.
Set oStartPoint = oLine.StartSketchPoint
Set o3DStartPoint = oSketchII.SketchToModelSpace(oStartPoint.Geometry)
' CreatePointGraphics o3DStartPoint, kEndPointStyle
Set oEndPoint = oLine.EndSketchPoint
Set o3DEndPoint = oSketchII.SketchToModelSpace(oEndPoint.Geometry)
' CreatePointGraphics o3DEndPoint, kFilledCircleSelectPointStyle
oStartHLSet.AddItem oStartPoint
oEndHLSet.AddItem oEndPoint
Next oEnt
oStartHLSet.Color = oGreen
oEndHLSet.Color = oRed
The primary problem with what you're trying to do is that the entities
you're trying to highlight are selected. The selection overrides the
highlight so you don't see anything. Here's a different implementation that
gets all of the selected lines, clears the selection, and then highlights
the end points.
Public Sub HighlightEnds()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
' Iterate over the contents of the select set looking for lines.
Dim colLines As New Collection
Dim oEnt As Object
For Each oEnt In oDoc.SelectSet
colLines.Add oEnt
Next
oDoc.SelectSet.Clear
' Create a green highlight set.
Dim oGreenHS As HighlightSet
Set oGreenHS = oDoc.CreateHighlightSet
oGreenHS.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
' Create a red highlight set.
Dim oRedHS As HighlightSet
Set oRedHS = oDoc.CreateHighlightSet
oRedHS.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
' Add the end points to the highlight sets.
For Each oEnt In colLines
Dim oSketchLine As SketchLine
Set oSketchLine = oEnt
' Add the start point to the green highlight set.
oGreenHS.AddItem oSketchLine.StartSketchPoint
' Add the end point to the red highlight set.
oRedHS.AddItem oSketchLine.EndSketchPoint
Next
MsgBox "Points are highlighted."
End Sub
Brian Ekins
Autodesk Inventor API
Ahh... That works perfectly!
Thanks Brian!
