HighLight Set
HighLight Set
HighLight Set
upgraded to IV12... my highlight set will no longer work. Anyone know why? It looks to be coded properly...
        Dim lNumbOfItems As Long
        For lNumbOfItems = 1 To oCurve.Count
            Dim oDrawingCurveSegment As Inventor.DrawingCurveSegment
            oDrawingCurveSegment = oCurve.Item(lNumbOfItems).Segments.Item(1)
            Dim oSet1 As Inventor.HighlightSet
            oSet1 = oDrawingDoc.CreateHighlightSet
            Call oSet1.AddItem(oDrawingCurveSegment)
        Next
 I would appreceiate any help?
Bill
Anyone?
skyngu
ilogic?
Autodesk Inventor Professional 2019
VB.net... Did the API change?
Anyone?
It seems as if the HighLightSet in IV12 will no longer support the curve segment in an exposed (visible) sketch on a drawing view or is it some type of bug or clitch? Is there a work around for this?
Public Sub HighLightSet()
Dim oDrawingDoc As Inventor.DrawingDocument
Set oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheets As Inventor.Sheets
Set oSheets = oDrawingDoc.Sheets
Dim oSheet As Inventor.Sheet
Set oSheet = oSheets.Item(1)
Dim oDrawingViews As Inventor.DrawingViews
Set oDrawingViews = oSheet.DrawingViews
Dim oDrawingView As Inventor.DrawingView
Set oDrawingView = oDrawingViews.Item(1)
Dim oRefComps As Inventor.Document
Set oRefComps = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oRefCompDef As Inventor.ComponentDefinition
Set oRefCompDef = oRefComps.ComponentDefinition
Dim oRefCompDefOccs As Inventor.ComponentOccurrence
Set oRefCompDefOccs = oRefCompDef.Occurrences.Item(1)
Dim oRefSubComps As Inventor.ComponentOccurrence
Set oRefSubComps = oRefCompDefOccs.SubOccurrences.Item(1)
Dim oRefSubCompsSubComps As Inventor.ComponentOccurrence
Set oRefSubCompsSubComps = oRefSubComps.SubOccurrences.Item(1)
Dim oSketchPartFils As Inventor.ComponentDefinition
Set oSketchPartFils = oRefSubCompsSubComps.Definition
Dim oSketches As Inventor.PlanarSketches
Set oSketches = oSketchPartFils.Sketches
Dim oSketch As Inventor.Sketch
Set oSketch = oSketches.Item(2)
Dim oPlanarSketchProxy As Inventor.PlanarSketchProxy
Call oRefSubCompsSubComps.CreateGeometryProxy(oSketch, oPlanarSketchProxy)
Call oDrawingView.SetVisibility(oPlanarSketchProxy, True)
Dim oCurve As Inventor.DrawingCurvesEnumerator
Set oCurve = oDrawingView.DrawingCurves(oPlanarSketchProxy)
Set oDrawingCurveSegment = oCurve.Item(lNumbOfItems).Segments.Item(1)
Dim oSet1 As Inventor.HighLightSet
Set oSet1 = oDrawingDoc.CreateHighlightSet
'Call oSet1.AddItem(oDrawingView)
Next
End Sub
This is really important...
