Highlight Selection while using ilogic
I have an illogic code that I have to select geometry on the drawing, is it possible to highlight my selections as I pick them so they stand out on screen?
WCrihfield
Are the selected items being selected entirely by the code, or is there an interactive portion that allows you to manually pick them with your mouse.
Perhaps if there was more info here, such as a copy of your code so far, and/or screen captured images of what your looking at.
These would probably help drive more and better replys.
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfieldIt's an on screen selection with the mouse. I can paste code in a while.
JelteDeJong
you could do something like this:
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim highlightSet As HighlightSet = doc.HighlightSets.Add()
highlightSet.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 255)
Dim line1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select line")
highlightSet.AddItem(line1)
Dim line2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select line")
highlightSet.AddItem(line2)
Dim line3 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select line")
highlightSet.AddItem(line3)
MsgBox("3 lines are highlighted")
highlightSet.Clear()
MsgBox("highlightSet is cleared")
Jelte de Jong
Blog: hjalte.nl - github.com
@JelteDeJongHow would that work with the following code?
Dim oDoc As DrawingDocument= ThisDoc.Document
Dim oView As DrawingView
Dim oSegment As DrawingCurveSegment
Dim oCcName As String
Dim comps As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim comp As Object
While True
comp = ThisApplication.CommandManager.Pick(16914, "Pick tangent edges TO KEEP, press ESC when finished.")
If IsNothing(comp) Then Exit While
comps.Add(comp)
End While
For Each comp In comps
oSegment = comp
oView = oSegment.Parent.Parent
oCcName = oSegment.Parent.ModelGeometry.Parent.Parent.name
For Each oCurve As DrawingCurve In oView.DrawingCurves
If oCurve.EdgeType = 82694 Then
If oCurve.ModelGeometry.Parent.Parent.name = oCcName Then
For Each DCSeg As DrawingCurveSegment In oCurve.Segments
DCSeg.Visible = False
Next
End If
End If
Next
Next
oSegment = comp
oSegment.Visible =True
Next
JelteDeJong
something like this. I have colored my changes red. (I changed 2 numers for there enums for more easy reading)
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim highlightSet As HighlightSet = oDoc.HighlightSets.Add()
Dim comp As Object
While True
    comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick tangent edges TO KEEP, press ESC when finished.")
    comps.Add(comp)
    highlightSet.AddItem(comp)
End While
For Each oSegment In comps
    oCcName = oSegment.Parent.ModelGeometry.Parent.Parent.Name
        If oCurve.EdgeType = DrawingEdgeTypeEnum.kTangentEdge Then
            If oCurve.ModelGeometry.Parent.Parent.Name = oCcName Then
                Next
            End If
        End If
    Next
Next
    oSegment = comp
    oSegment.Visible = True
Next
Jelte de Jong
