Hiding workplanes in generated jpg images
MikeGillam5072
MikeGillam5072
I have an application that generates and stores jpg images of Inventor models.
I would like to hide a workplane in the generated image.  I made the workplane invisible (unchecked visibility) in both the Master and Default views, but the workplane is still visible in the generated image.
Here's the snippet of VB code that generates the jpg:
      Dim oDoc As Inventor.Document = OpenDoc(model)
       Dim oView As Inventor.View = Nothing
       oView = oDoc.Views.Item(1)
       Dim oCamera As Inventor.Camera
        oCamera = oView.Camera
        oCamera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopRightViewOrientation
        oCamera.SetExtents(64, 64)
        oCamera.Fit()
        oCamera.Apply()
        oView.SaveAsBitmap(target, 64, 64)
Any ideas?
Mike G
YuhanZhang
Can you try to export the view thru UI(Export->Image) to an image to see if the work plane also is there after you hide it? Is it possible to attach the model document so we can see to this issue?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
MikeGillam5072
When I export it using the Inventor UI, it works fine (i.e. the workplane is hidden).
It appears to be related to the API.
I added a workplane to a simple model (cabinet.iam) and attached it.
sanjay.ramaswamy
Any design view changes (such as visibility) made to the master design view are never saved. And the Documents.Open API call opens the document in Master by default. So you should make changes to the default (or some other design view) and then open the document in that particular design view. Use Documents.OpenWithOptions method to specify a design view to open the document in.
ekinsb
Are you sure it's a work plane that's being displayed?  When I test your code I don't see a work plane but I do see the 3D triad that's usually displayed in the lower-left of the screen.  Because the image you're creating is so small it ends up being closer to the center of the image and fills a large portion of it.  You can turn off the display of the 3D indicator.  Here's a VBA version of your program that I used for testing.
Public Sub SaveView()
    Set oDoc = ThisApplication.ActiveDocument
    Dim oView As Inventor.view
    Set oView = ThisApplication.ActiveView
    Set oCamera = oView.Camera
    Call oCamera.SetExtents(64, 64)
    oCamera.Fit
    oCamera.Apply
    ThisApplication.DisplayOptions.Show3DIndicator = False
    Call oView.SaveAsBitmap("C:\Temp\test.bmp", 64, 64)
    ThisApplication.DisplayOptions.Show3DIndicator = True
End Sub
Brian Ekins
Mod the Machine blog
MikeGillam5072
That fixed it, and thanks for the tip on hiding the 3d indicator.
thanks
Mike G
