Hide document after opening
MistakenEngineer
MistakenEngineer
I've created a catalog assembly where we house all of our parts and subassemblies from our custom library. I have also made a macro call "PlaceFromCatalog" that opens up the assembly, allows you to select the parts you want, closes the catalog, and allows you to place the part in the other assembly. I am wondering if there is a way to hide the catalog without closing it. I would like to do it this way because every time you close the catalog it resets the undo feature and I want to be able to undo the placement of the parts in a different assembly. I also want to do it this way so that it opens quicker. I'm already opening the catalog with "All Components Suppressed" but I still want it to open faster. If I close the catalog assembly within the "PlaceFromCatalog" command transaction, sometimes it clears the undo. According to the help, it says I can close the document within the same transaction and it will work but if I activate another command and then end the transaction it will crash.
As per "Supporting Undo" in the "Inventor API User's Manual":
Dos and Don'ts
  • An Undo or Redo should be performed only when there is no transaction in progress (during an unidentified transaction).
  • Do not wrap any Inventor commands within transactions. Do not wrap any user interaction events within transactions. A good rule would be that it is OK to create modal dialogs within a transaction but not modeless dialogs.
  • The transaction event handling code should not perform any operation that uses transactable memory. For example, it is illegal to create a sketch line in the event handling code for the commit of a transaction.
  • Do not close any document inside a transaction, even the active one. The exception to this rule is that it is legal to close a document in a transaction when the document was opened in that exact same transaction.
Dim oTxnMgr As TransactionManager
Set oTxnMgr = ThisApplication.TransactionManager
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oTxn As Transaction
Set oTxn = oTxnMgr.StartTransaction(oDoc, "Txn1")
' Invalid operation
oDoc.Close
oTxn.End
I just figured the easiest way to pull parts from the catalog is to already have it open and just hide it after use since we use it quite a lot and it will speed things up. I just don't know how to do it. Here is my code for reference:
Quick question: how do I add a spoiler?
Sub PlaceFromCatalog()
    ' Make sure you are in an assembly environment
    If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then Exit Sub
    ' Stops a different macro that causes interference with this one
    Set oiMateEditor = Nothing
    ' Starts the transaction to allow undo
    Set oTxn = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "InsertFromCatalog")
    ' Calls a function that opens the catalog and returns the document
    Set oCatalog = openCatalog
    ' Creates a class that monitors UserInputEvents and DocumentEvents to see
    '       if a component is selected or if the catalog is closed
    Set oSelect = New SelectClass
    ' Waiting for something to happen
    Do While oSelect.oLocation = ""
        DoEvents
    Loop
    ' If a component is selected, the location of the file in the library is returned...
    oLocation = oSelect.oLocation
    Set oSelect = Nothing
    ' If the document is closed by the user, the string "canceled" is returned
    '       and cleanup begins to stop the command
    If oLocation = "Cancel" Then
        ' Ending the transaction has caused me an error before which is why I
        '       tell the code to ignore errors
        On Error Resume Next
        oTxn.End
        On Error GoTo 0
        ' This starts the other another macro that I ended which needs to be running
        Set oiMateEditor = New ReUsableiMateHandler
        Exit Sub
    ' If multiple components are selected, they are copied into memory and the
    '       SelectClass returns "Copied"
    ElseIf oLocation = "Copied" Then
        oCatalog.Close (True)
        oTxn.End
        On Error GoTo 0
        Set oCatalog = Nothing
        Exit Sub
    ' A component has been selected
    ' This transaction captures the opening and closing of the catalog
    oTxn.End
    On Error GoTo 0
    ' Start a new transaction that captures placing the components
    Set oTxn2 = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Place From Catalog")
    Dim cmdMgr As CommandManager
    Set cmdMgr = ThisApplication.CommandManager
    ThisApplication.AssemblyOptions.UseiMate = False
    ' Post the file Location so that way the dialog for the Place Command doesn't open
    Call cmdMgr.ClearPrivateEvents
    Call cmdMgr.PostPrivateEvent(kFileNameEvent, oLocation)
    ' Execute the "Place Component" command synchronously and wait for it to finish
    Call cmdMgr.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute2(True)
    oTxn2.End
End Sub
clutsa
Function OpenWithOptions(FullDocumentName As String, Options As NameValueMap, [OpenVisible As Boolean = True]) As _Document
When you open the catalog can you use the "OpenWithOptions" and set the third parameter to false?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
MistakenEngineer
Unfortunately, it doesn't work. It appears there is no way to hide a document after opening it.
