Hide break lines in ISO view
Message 1 of 9
Hi all,
This is my first post on the Inventor Customization board.
I am curious to know if anyone knows of a way to hide the break lines that are created during a projected view.  I'm constantly hiding them by selecting them individually, which can be tedious in complex parts.
I like to think I'm good at programming, but I'm not and expert.  Still lots to learn.
So far it seems like they are not able to be put on a separate layer like the break itself.
Thanks is advance for any suggestions.
Replies (8)
Message 2 of 9
RodrigoEiras
Could you clarify which are "the break lines that are created during a projected view" you are referring to?. A screenshot would be perfect!
Message 3 of 9
Message 4 of 9
RodrigoEiras
Normally that line should not appear. Maybe is related to the way the part is created. Is it an only solid or two solids?.
If you could share the file I would try to make a projected view and give you some feedback.
Best regards
Message 5 of 9
Here is a sample file.  The break line gap is set to .001mm  we have many parts that require 5-6 breaks on a drawing to fit and still show all the features.
Message 6 of 9
RodrigoEiras
Hi Payne530,
I also need the referenced part/s to be able to see the example. Please send it when possible.
Best regards
Message 7 of 9
Oops sorry about that.  Here is the related part file.  Hope this works.
Message 8 of 9
Hi all,
I had an epiphany last night and wrote this little bit of code.
Private Sub HideBreakLinesInIso(ByRef oDrawingView As DrawingView)
    Dim oDrawingCurves As DrawingCurvesEnumerator
    Dim oDrawingCurve As DrawingCurve
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Dim oBreakFace As Face
    Dim oCreatedByFeature As PartFeature
    Dim oBreakCurves As ObjectCollection
    Set oBreakCurves = ThisApplication.TransientObjects.CreateObjectCollection
    Set oDrawingCurves = oDrawingView.DrawingCurves
    For Each oDrawingCurve In oDrawingCurves
        If TypeName(oDrawingCurve.ModelGeometry) = "Face" Then
            Set oBreakFace = oDrawingCurve.ModelGeometry
            On Error Resume Next 'Turn error checking off
            Set oCreatedByFeature = oBreakFace.CreatedByFeature 'Throws error if no createdbyfeature
            On Error GoTo 0 'Turn error checking on
            Select Case Err
                Case 0 'No error occured
                    If TypeName(oCreatedByFeature) = "ReferenceFeature" Then 'Edge belongs to the reference plane used in the break operation
                        For Each oDrawingCurveSegment In oDrawingCurve.Segments
                            oDrawingCurveSegment.Visible = False
                        Next
                Case -2147467259 'Method 'CreatedByFeature' of object 'Face' failed
                    'Unhandled
                Case Else
                    Debug.Print "ERROR: " & Err.Number & " " & Err.Description
                    Debug.Assert False
            End Select
    Next
End Sub
  This will hide the drawing curves created by the break object in a view.
We handle really long parts on a daily basis that we usually break in multiple spots.  The guys on the shop floor like to have an Iso view of the parts.
Message 9 of 9
Hi Payne
Thanks for this code..
I have tried to get this working in Inventor pro 2016 as is, but it won't register it in the macro list (to do with the contents of the sub line (not sure how to launch this, so i decided to have a crack at a macro that could be run across multiple sheets and views at the same time (you'll have to excuse my noob-ness)
I get no erros when I run this, but the view I am testing remains unchanged:
Sub HideBreakLinesInIso()
    Dim oDocument As DrawingDocument
    Dim oSheets As Sheets
    Dim oSheet As Sheet
    Set oDocument = ThisApplication.ActiveDocument
    Set oSheets = oDocument.Sheets
    For Each oSheet In oSheets
        Dim oDrgViews As DrawingViews
        Set oDrgViews = oSheet.DrawingViews
        Dim oDrgView As DrawingView
        For Each oDrgView In oDrgViews
        Set oDrawingCurves = oDrgView.DrawingCurves
                    Select Case Err
                                Next
                            'Unhandled
                        Case Else
                            Debug.Assert False
                    End Select
            Next
        Next
    Next
End Sub
I am guessing it is to do with how it is exiting out of the views after each loop, and possibly annihilating any changes to the visible switches on the line segments.
any help would be greatly appreciated!
Matt
