Help with try and catch, ilogic to update parts length when part is changed.
I need help with this code..it works really well I just kinda combine what I found here on forum and with the great help of a lot of people esp. Curtis of course we all know who he is.
The issue is when running it for the first time, its great but when I change the part shape or dimensions.  because of the try and catch function, it doesn't update my length ei ("B_L") parameters.  it keeps the existing.  my workaround it is to erase parameter but there must be something here for a fix.
and if I remove the try and catch well it creates a new "B_L1" parameter...but with the right length.
Thanks a bunch!
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 76787 StartFragment: 314 EndFragment: 76755 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'MEASURES OVERALL X, Y, AND Z DIMENSIONS
X_MEASURE = Measure.ExtentsLength
Y_MEASURE = Measure.ExtentsWidth
Z_MEASURE = Measure.ExtentsHeight
'SORTS MEASURED DIMENSIONS TO FIND THE LENGTH, WIDTH AND HEIGHT OF PART
xdim = MaxOfMany(X_MEASURE,Y_MEASURE,Z_MEASURE)
ydim = MinOfMany(X_MEASURE,Y_MEASURE,Z_MEASURE)
zdim = (X_MEASURE + Y_MEASURE + Z_MEASURE) - xdim - ydim
'ROUNDS DIMENSIONS TO NEAREST 1/16"
dimx = Round(xdim*16 ul)*.0625
dimy = Round(ydim*16 ul)*.0625
dimz = Round(zdim*16 ul)*.0625
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
'ADDS A ZERO If DIMENSION DISPLAYS X.5'ADDS TWO ZEROS IF DIMENSION DISPLAYS X
If (Round(dimx,0)+1)-dimx = .5 Then
dmx = dimx & ""
ElseIf (Round(dimx,0)+1)-dimx = 1 Then
dmx = dimx & ""
Else dmx = dimx
If (Round(dimy,0)+1)-dimy = .5 Then
dmy = dimy & "0"
ElseIf (Round(dimy,0)+1)-dimy = 1 Then
dmy = dimy & ""
Else dmy = dimy
If (Round(dimz,0)+1)-dimz = .5 Then
dmz = dimz & ""
ElseIf (Round(dimz,0)+1)-dimz = 1 Then
dmz = dimz & ""
Else dmz = dimz
'CREATES CUSTOM iPROPERTY FOR THE BOM
iProperties.Value("Custom", "B_L") = dmx
iProperties.Value("Custom", "B_W") = dmz
iProperties.Value("Custom", "B_T") = dmy
' Set up parameters
' Get the active document.  Assumes a part document is active.
Dim partDoc As PartDocument
partDoc = ThisDoc.Document
'partDoc = ThisApplication.ActiveDocument
'get filename
Filename = ThisDoc.FileName(False)
'get the drawing number
drawingnumber = Left(filename,8)
'get description name
description = Mid(filename,10, 40)
' Get the UserParameters collection
Dim userParams As UserParameters
userParams = partDoc.ComponentDefinition.Parameters.UserParameters
Try
    oTest = Parameter("B_L")
    Catch
    param = userParams.AddByExpression("B_L", dmx, UnitsTypeEnum.kInchLengthUnits)
    param = partDoc.ComponentDefinition.Parameters.Item("B_L")
    param.ExposedAsProperty = True
    param.CustomPropertyFormat.Units = "in"
    param.CustomPropertyFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
    param.CustomPropertyFormat.ShowTrailingZeros = False
    param.CustomPropertyFormat.ShowUnitsString = False
End Try
Try
    oTest = Parameter("B_W")
    Catch
    param = userParams.AddByExpression("B_W", dmz, UnitsTypeEnum.kInchLengthUnits)
    param = partDoc.ComponentDefinition.Parameters.Item("B_W")
End Try
Try
    oTest = Parameter("B_T")
    Catch
    param = userParams.AddByExpression("B_T", dmy, UnitsTypeEnum.kInchLengthUnits)
    param = partDoc.ComponentDefinition.Parameters.Item("B_T")
    param.CustomPropertyFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
End Try
'oB_TConverted = Parameter("B_T")
oBT = RoundToFraction(dmy, 1/32, RoundingMethod.Round)
fBT = oBT & """"
'select the case for B_T
Select Case dmy
    Case 0.1196
        oVNR = "445-0011"
    Case 0.1345 '10GA
        oVNR = "445-0010"
    Case 0.1875
        oVNR = "445-0203"
    Case 0.25
        oVNR = "445-0204"
    Case 0.3125
        oVNR = "445-0205"
    Case 0.375
        oVNR = "445-0206"
    Case .5
        oVNR = "445-0208"
    Case 0.625
        oVNR = "445-0210"
    Case 0.75
        oVNR = "445-0212"
    Case 0.875
        oVNR = "445-0214"
    Case 1
        oVNR = "445-0216"
    Case 1.125
        oVNR = "445-0218"
    Case 1.25
        oVNR = "445-0220"
    Case 1.375
        oVNR = "445-0222"
    Case 1.5
        oVNR = "445-0224"
    Case 1.75
        oVNR = "445-0228"
    Case 2
        oVNR = "445-0232"
    Case 2.125
        oVNR = "445-0234"
    Case 2.25
        oVNR = "445-0236"
    Case 2.375
        oVNR = "445-0238"
    Case 2.5
        oVNR = "445-0240"
    Case 2.75
        oVNR = "445-0244"
    Case 3
        oVNR = "445-0248"
    Case 3.25
        oVNR = "445-0252"
    Case Else
        oVNR = "445-????"
End Select
'[ set iproperties
iProperties.Value("Custom", "Thickness") = fBT
'iProperties.Value("Project", "Stock Number") = drawingnumber
iProperties.Value("Project", "Vendor") = oVNR
'iProperties.Value("Project", "Description") = description
iProperties.Value("Project", "WEB Link") = "=PL, MS, HR, <Thickness>"
iProperties.Value("Project", "Cost Center") = "=<B_W> x <B_L>"
DNL = Mid(filename,9,4)
If DNL < 10 Then
iProperties.Value("Summary", "Category") = Mid (filename, 12,1)
Else
iProperties.Value("Summary", "Category") = Mid (filename, 11,2)
'check part if its single part
Dim spart As String
spart = Mid(filename,9,2)
'If filename .contains("-") Then
If spart = "00" Then
iProperties.Value("Project", "Stock Number") = iProperties.Value("Project", "Vendor")
'iProperties.Value("Project", "Cost Center") = oPRJ
iProperties.Value("Project", "Description") = iProperties.Value("Project", "WEB Link")
'iProperties.Value("Summary", "Category") = DNL
Else
If oVNR = "445-0011" Then
iProperties.Value("Project", "WEB Link") = "=PL, MS, HR, #11 GA"
If oVNR = "445-0010" Then
iProperties.Value("Project", "WEB Link") = "=PL, MS, HR, #10 GA"
odrawingname = ThisDoc.FileName(False)
opartname = Mid(odrawingname, 5,8)
I added this before the try and catch for B_L and it seems to work..not sure if this is the best way to go about it but it works for now
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 1227 StartFragment: 314 EndFragment: 1195 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
param.Delete
richard.joseph.pollak
It looks like the problem is that you're only setting the value if it fails the 'Try'
Try it this way:
Try
    Parameter("B_L") = dmx
Catch
   End Try
   I made a mistake when I first replied that I have edited.
