Help with GetNormalAtPoint in C# needed (VB.Net - OK)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'm trying to convert my VB.Net project to C# (some employers prefer C#) and I feel a bit confused with usage of GetNormalAtPoint method (on the same dataset it fails to return same result as VB.Net does).
VB.Net code (piece of interest):
Call oFrF.Evaluator.GetNormalAtPoint(pt, n)
MessageBox.Show("oFrF.TransientKey = " & oFrF.TransientKey & vbCrLf & "pt : " & pt(0) & "  ;  " & pt(1) & "  ;  " & pt(2) & vbCrLf & "n : " & n(0) & "  ;  " & n(1) & "  ;  " & n(2), "VB")
C#:
oFrF.Evaluator.GetNormalAtPoint(pt, n);
MessageBox.Show ("oFrF.TransientKey = " + oFrF.TransientKey + System.Environment.NewLine + "pt : " + pt[0] + "  ;  " + pt[1] + "  ;  " + pt[2] + System.Environment.NewLine + "n : " + n[0] + "  ;  " + n[1] + "  ;  " + n[2],"C#");
I'm expecting to get the same coordinates of n (Point) on same "oFrF" (Face) and "pt" (Point) but I get zero:
What I'm missing?
Please vote for Inventor-Idea Text Search within Option Names
Michael.Navara
You miss the 'ref' keyword in method calls
var part = ThisDoc.Document as PartDocument;
var face = part.ComponentDefinition.SurfaceBodies[1].Faces[1];
var pointOnFace = face.PointOnFace;
double[] point = { };
pointOnFace.GetPointData(ref point);
double[] normal = {};
face.Evaluator.GetNormalAtPoint(ref point,  ref normal);
MessageBox.Show(string.Join(";", normal));
Maxim-CADman77
Yes, correct C#-code is:
oFrF.Evaluator.GetNormalAtPoint(ref pt, ref n)
... seems a bit strange that Visual Studio* IntelliCode does not detect an issue if no keyword is used ... while it gives correct hint if the wrong keyword (ex. 'out') is used:
Thank you so much!
* I'm using VS Community 2019 version 16.11.16
