Help to create automatically a view representation
johan.degreef
Advisor Advisor
johan.degreef
Could anyone help me to create an ilogic button that would create or update a "View Representation" on the current "Model State". The button is used in an assembly.
- The view representation's name should be "PF_<modelstatename>" (model state: primary - view representation: PF_primary)
- The view representation should only show parts which custom iproperty "PTN_CODE",  does contain the values "FITT" or "VINK" or "BEND". (other parts uncheck visibility)
- It should not cycle through subassemblies
I think it is not that large code, but I don't know where to start.
Many Thanks if someone finds the time, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
jnowel
Not sure if this is what you're looking for.
You should activate the specific ModelState for the ViewRepresentation to properly show.
Sub Main
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
	For Each oModelState As ModelState In oDoc.ComponentDefinition.ModelStates
		Dim oViewRepName As String
		oViewRepName = "PF_" & oModelState.Name
		Dim oViewRep As DesignViewRepresentation
		Try
			oViewRep = oDoc.ComponentDefinition.RepresentationsManager.DesignViewRepresentations(oViewRepName)
		Catch
			oViewRep = oDoc.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Add(oViewRepName)
		End Try
		oModelState.Activate
		oViewRep.Activate
		'oViewRep.Locked = False
		For Each oOcc As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
			If oOcc.Suppressed = True Then Continue For
			Dim oOccDoc As Document
			oOccDoc = oOcc.Definition.Document
			Dim PTN_CODE As String
			PTN_CODE = GetCustomiPropValue(oOccDoc, "PTN_CODE")
			'Logger.Info(oOccDoc.DisplayName & " - " & PTN_CODE)
			Select Case PTN_CODE
				Case "FITT", "VINK", "BEND"
					oOcc.Visible = True
				Case Else
					oOcc.Visible = False
			End Select
		Next
		'oViewRep.Locked = True
		ThisApplication.ActiveView.GoHome
		ThisApplication.ActiveView.Fit
	Next
End Sub
Function GetCustomiPropValue(oRefDoc As Document, iProp As String) As String
	Try
		Return oRefDoc.PropertySets.Item("User Defined Properties").Item(iProp).Value
	Catch
		Return String.Empty
	End Try
End Function
johan.degreef
@jnowel Many thanks for this quick solution!
