Help to Bolt size rule
h.hartwig
h.hartwig
Hey, i hope some of you can help me witch my rule
I have a multiple text parameter eg M6 M8 etc, I try to make a rule, so when I change the text M6 to M8 then should the hole and counterbore sizes change so it fits the selected bolt size
I attach the part and hope some of you can help,  it works if I use numbers, but how get it done witch text?
Michael.Navara
You need to compere string with string
If Hole_Set_1_Bolt_Size = "M6" Then
'This bolt sizes accords to DIN 974-1 Standard - ISO 4762 Bolts
'Hole Set 1
	Parameter("Count_Dia_set_1") = 11
	Parameter("Count_Depth_set_1") = 6.4
	Parameter("Hole_Dia_set_1") = 6.6
ElseIf Hole_Set_1_Bolt_Size = "M8" Then
	Parameter("Count_Dia_set_1") = 20
	Parameter("Count_Depth_set_1") = 10
	Parameter("Hole_Dia_set_1") = 15
h.hartwig
Thanks for the fast answer, 🙂
