Help: Set Button Size with Large Size in Default
ngdnam88
ngdnam88
Dears,
I'm a new in API with VS. Please help me how to set the Button Size in the Ribbon Tab with large size in default or large size only?  - I'm using this code.  (In this case I wanna some button always in large size = "LargeIcon_32x32")
Dim oCtrlDefs As ControlDefinitions = m_inventorApplication.CommandManager.ControlDefinitions
mButtonDef = oCtrlDefs.AddButtonDefinition( _
		"Custom Cmd", _
		"Company:AddInName:Button1", _
		CommandTypesEnum.kQueryOnlyCmdType, _
		"AddInGuid", _
		"Description", _
		"Tolltip text", _
		StandardIcon_16x16, _
		LargeIcon_32x32, _
		ButtonDisplayEnum.kDisplayTextInLearningMode)
Thanks you!
JelteDeJong
In the code that you shared the ControlDefinition is defined. The button size is a property of the CommandControl. in your code you should have something like this:
Dim ribbon As Ribbon = _inventor.UserInterfaceManager.Ribbons.Item("Assembly")
Dim ribbonTab As RibbonTab = ribbon.RibbonTabs.Item("id_TabManage")
Dim ribbonPanel As RibbonPanel = ribbonTab.RibbonPanels.Item("iLogic.RibbonPanel")
Dim control As CommandControl = ribbonPanel.CommandControls.AddButton(mButtonDef)
control.UseLargeIcon = True
Jelte de Jong
Blog: hjalte.nl - github.com
ngdnam88
Thank you very much! @JelteDeJong
