Help_ Im trying to subtract height when I unsuppress / add a chamfer-ilogic rule
I am trying to set up an ilogic rule to subtract 25 from a door when I click true on the form (Add a chamfer)
False and no chamfer = original height
True and chamfer = original height - 25mm
Im having some trouble.
Appreciate if someone could help me out
Thanks.
Parameter Form
Parameter
("Gable Left", "Depth") = Depth Parameter("Gable Left", "Height") = Height Parameter("Bottom", "Width") = Width Parameter("Bottom", "Depth") = Depth Parameter("Gable Right", "Depth") = Depth Parameter("Gable Right", "Height") = Height Parameter("Top:1", "Depth") = Depth Parameter("Top:1", "Width") = Width Parameter("Back", "Width") = Width Parameter("Back", "Height") = Height - 36 Parameter("Door", "Width") = Width +31 Parameter("Door", "Height") = Height
Suppression Form
Feature.IsActive("Back", "Cut") = Back_CUT
Feature.IsActive("Door", "Chamfer1") = Chamfer
Feature.IsActive("Door", "RIGHT HANDLE") = Handle_Right
Feature.IsActive("Door", "LEFT HANDLE") = Handle_Left
WCrihfield
If you could attach screen captures of your Forms, Parameters, & Geometry and/or the part file itself, it would be easier for us to help you.
I assume by looking at your code that this is a local iLogic rule, right?
I assume also that, in your lower section of code, Back_CUT, Chamfer, Handle_Right, & Handle_Left are local Boolean type Parameters, correct?
   -If not, then you need to replace them with either True, False, or a Boolean type Parameter.
What effect are changing those features supposed to have on the parts?
Wesley Crihfield
(Not an Autodesk Employee)
Thanks for the reply,
see attached pdf.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
It would be better if you can provide non confidential assembly files to investigate.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
