Help: iLogic Change Label of Drawing Views
ngdnam88
Message 1 of 9
ngdnam88
Hi All,
Please help me an iLogic Code to change the drawing view name as this picture.
I really read some topic that relative to my question (https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-code-to-change-view-label-text/m... ) but in this case I only need to change the Label of View: ex. View 1 -> ISOMETRIC VIEW.
Thanks!
Replies (8)
Message 2 of 9
GosponZ
'This in CAPITAL change for your need. Run rule select which view you need and click on view. Hope it will help
Dim
oList As String() = {"TOP VIEW","FRONT VIEW","FRONT VIEW @ REAR WALL","END VIEW ","EXPLODED VIEW ","BOTTOM VIEW","BACK VIEW","ISOMETRIC","ISOMETRIC-BACK", "ISOMETRIC-BOTTOM", "ISOMETRIC @ SIDE AND REAR WALL", "FLAT PATTERN"} Dim LabelName As String = InputListBox( _ "Select Label Name and then Pick Drawing View", _ oList, "", Title := "Label Names") If LabelName <> "" Then ' Get a drawing view selection from the user Dim oObject As Object oObject = ThisApplication.CommandManager.Pick( _ SelectionFilterEnum.kDrawingViewFilter, "Pick a feature") Dim oView As DrawingView = oObject oView.ShowLabel = True oView.Label.FormattedText = LabelName End If Beep
Message 3 of 9
ngdnam88
But I just wanna change Label Text as in this picture not in the Format Text. Is it possible with iLogic? Thanks,
Message 4 of 9
GosponZ
just do if you want what i offer you. You can replace all day long
Message 5 of 9
ngdnam88
Sorry, maybe my question is not clear.
Please see my picture, I just wanna to change Label Text in the "Model Tree" as this picture:
Thank you very much!
Message 6 of 9
A.Acheson
Use
oView.Name
Instead of
oView.Label
If I am not mistaken the formatted text on the label would be to overwrite the original contents of the label.
Regards
Alan
Message 7 of 9
ngdnam88
Thanks all of you!
It's done now.
Message 8 of 9
maxim.teleguz
can you share your updated code so we dont go through testing what was changed?
Message 9 of 9
ngdnam88
I just edited GosponZ's + A.Acheson's Codes:
Dim oList As String() = {"TOP VIEW","FRONT VIEW","FRONT VIEW @ REAR WALL","END VIEW ","EXPLODED VIEW ","BOTTOM VIEW","BACK VIEW","ISOMETRIC","ISOMETRIC-BACK", "ISOMETRIC-BOTTOM", "ISOMETRIC @ SIDE AND REAR WALL", "FLAT PATTERN"}
Dim LabelName As String = InputListBox("Select Label Name and then Pick Drawing View", oList, "", Title := "Label Names")
'Get a drawing view selection from the user
oObject = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick a feature")
oView.Name.FormattedText = LabelName
Beep
