Having trouble with setting custom parameters
outdagawoods
Observer Observer
outdagawoods
Observer
Observer
 I have set up my parameters the problem is when I go to dimension a line and a sketch and I click my list of parameters from the dimension drop-down tree it is not in the tree if I go back and manually put the dimension in and then go back to my parameters tab it will show up in model parameters but not in the user parameters you will have a d 1 or something like that and then I have to go in and input the name of the parameter that I want to use instead of being able to just type the name of the parameter for length or width or height and it automatically dimension it to my previous values
J-Camper
Why are all your Parameters "Text" Parameters?  They Should be numeric:
See the Unit/Type ColumnSee the Unit/Type ColumnText Type Parameter doesn't show upText Type Parameter doesn't show up
outdagawoods
Observer
Observer
Thank you sir worked like a charm. I am a new boob to this maybe later I'll hit you with something else that I get frustrated with thank you once again.
