Hey Guys,
I am new to the iLogic side of inventor but want to learn it to help make my work more efficient. I've been doing some research and working through some tutorials form Autodesk University and some other examples I've found on youtube. I am currently trying to use iLogic to pull parameter values from and excel spread sheet. I'm having a lot of trouble with the command GoExcel.CellValue. Every time I run that command it gives me an error message. I have included screen shots of the error message and the code I am trying to use. In the test code, I simply trying to set the plate_width parameter value equal to the value of cell in the the spreadsheet. I've double checked the spelling of the file names, file locations, and cell location. Have any of you experienced this? I can't figure it out. Thanks in advance for any help.
