Having difficulty with FindUsingRay method
dylanTEV9W
dylanTEV9W
Hi all I wrote a program that is supposed to return the intersection of a ray and a surface but I'm not having much luck with it so far. It should print out a 1 for the found_entities ObjectEnumerator if the ray going through a surface but I've only gotten zeros back from it. Even when I surrounded the origin with a sphere.
'defines base sketch, active application, active document and transient geometry before
'pulling anything from the active document
'Dim oSketch As PlanarSketch
'oSketch = _invApp.ActiveEditObject 'set the planar sketch as the active edit object
Dim part_doc As PartDocument ' get the active part document
part_doc = _invApp.ActiveDocument 'set part_doc as the active part document
Dim trans_geo As TransientGeometry 'get transient geometry from the application
trans_geo = _invApp.TransientGeometry 'set trans_geo as Transient Geometry object
'get the part component
Dim oDef As PartComponentDefinition
oDef = part_doc.ComponentDefinition
'define a neutral object to hold whats been picked
Dim oObject As Object
'select the surface to project to
oObject = _invApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a surface")
Dim oSurface As Face 'define a face.
oSurface = oObject ' set oSurface as the selected surface.
Dim vect As UnitVector 'define a vector
vect = trans_geo.CreateUnitVector(1, 1, 1)
Dim point1 As Point
point1 = trans_geo.CreatePoint(0, 0, 0)
Dim dist As Double = 0
'Entities for sending Find using ray outputs
Dim found_entities As ObjectsEnumerator = _invApp.TransientObjects.CreateObjectCollection()
Dim locate As ObjectsEnumerator = _invApp.TransientObjects.CreateObjectCollection()
'Dim point2 As Point
oDef.FindUsingRay(point1, vect, 0.0001, found_entities, locate, True)
Debug.Print(found_entities.Count)
dylanTEV9W
In looking for a solution I found a great lab on Mod the machine from 2012. Lab 5 in the series features the FindUsingRay command, which I was able to get working I commented out most of the rest of the changes and had it print out the location on the intersection with the object and the ray.
Private Sub Button4_Click(sender As Object, e As EventArgs) Handles Button4.Click
' Get PartComponentDefinition
Dim oCompDef As PartComponentDefinition
oCompDef = _invApp.ActiveDocument.ComponentDefinition
' Get the SurfaceBody
Dim oBody As SurfaceBody
oBody = oCompDef.SurfaceBodies.Item(1)
' Get the TransientGeometry
Dim oTG As TransientGeometry
oTG = _invApp.TransientGeometry
' 1. Declare to ObjectsEnumerator objects. One will be for Found Entities
' the other will be for located points
Dim oFoundEnts As ObjectsEnumerator = Nothing
Dim oLocPoints As ObjectsEnumerator = Nothing
' 2. Use FindUsingRay method fo the SurfaceBody instantiated above
' (oBody). for the first parameter use the TransientGeometry object
' CreatePoint use (0,0,0). For the second parameter use TransientGeometry
' CreateUnitVecor with a value of (0,0,-1). Ise 0.00001 for the radius
' then passin the Found entities varaible and located points variable
' declared above. Use True for the last parameter FindFirstOnly
Call oBody.FindUsingRay(oTG.CreatePoint(0, 0, 0),
oTG.CreateUnitVector(0, 0, -1), 0.00001,
oFoundEnts, oLocPoints, True)
' 3. Use and if statement to see if the Found entities varaible
' count property equals one. If it does not display a MsgBox that
' "No face is along the specified ray.
If oFoundEnts.Count = 1 Then
' 2. If Found entities does equal one declare a Face object
' and instantiate it using the first Item in the Found entities
' variable. Use a MsgBox and display the area of the face.
'Dim oFace As Face
Debug.Print(oLocPoints.Count)
Debug.Print(oFoundEnts.Count)
Dim point1 As Point
point1 = oLocPoints.Item(1)
Debug.Print("Location of intersection Point")
Debug.Print(point1.X)
Debug.Print(point1.Y)
Debug.Print(point1.Z)
'oFace = oFoundEnts.Item(1)
'MsgBox("Found face with area " & oFace.Evaluator.Area & " cm^2")
'' 3. Declare an Edge varaible and instantitate it using
'' the Edges collection of the face. (Item)
'Dim oEdge As Edge
'oEdge = oFace.Edges.Item(1)
'' 4. Declare an FilletFeatures variable and instantiate it with
'' the FilletFeatures property of the Features collection of the
'' PartComponentDefinition
'Dim oFilFeatures As FilletFeatures
'oFilFeatures = oCompDef.Features.FilletFeatures
'' 5. Declare a EdgesCollection and instantiate it using
'' CreateEdgeCollection of the TransientObjects of the application
'' use the Add method and add the edge from step 4.
'Dim oFilletEdges As EdgeCollection
'oFilletEdges = _invApp.TransientObjects.CreateEdgeCollection
'oFilletEdges.Add(oEdge)
'' 6. Create the fillet with the AddSimple method of the
'' FilletFeatures collection. Pass in the EdgeCollection from step 5
'' Use a radius of .5 for the second parameter
'Dim oFillet As FilletFeature
'oFillet = oFilFeatures.AddSimple(oFilletEdges, 0.5)
Else
MsgBox("Please Align the points such that they overlap the part.")
End Sub
