Have anybody gotten the Vault Check-in snippet to work?
fridtjofZM5ME
fridtjofZM5ME
The following snippet comes with the R2024 installation, but when I try to run it it does absolutely nothing. No errors, no nothing. Anybody got any good ideas of how to make it work?
Sub CheckIn()
	Try
		ThisDoc.Save
		Dim oControlDef As Inventor.ControlDefinition
		oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
		oControlDef.Execute2(True)
	Catch ex As Exception
		Logger.Error("Undo Check-In failed; likely, the file wasn't checked out.")
	End Try
End Sub
Curtis_Waguespack
Hi @fridtjofZM5ME
I don't think so.
What version of Inventor are you using?
If you are using Inventor 2024 there are built in ilogic Vault functions:
https://www.youtube.com/watch?v=6-GNaoGu40w
If using Inventor 2020 to 2023 see this link:
https://www.autodesk.com/autodesk-university/class/iLogic-and-Vault-Vault-and-iLogic-2020
I hope this helps.
Curtis
fridtjofZM5ME
Yes, this is the 2024 release of both programs, and the above code is from the built-in snippets.
It would appear after posting this that it might be a Vault issue with the add-in not loading properly or something like that.
JelteDeJong
I did not like some of the snippets in the first release of Inventor 2024. Im not sure if they have already released some better snippets. Anyway, have a look at this slightly altered version of the snippet:
Try
	ThisDoc.Save
	MsgBox("Check-In failed; likely, the file wasn't checked out.")
End Try
it should at least show a message box telling you that it did not work.
Jelte de Jong
Blog: hjalte.nl - github.com
Martin-Winkler-Consulting
Hi, i am using this class in VB.Net. (not checked with IV2024)
May be it is usefull for you.
Public Class Vault_Inventor_Addin
#Region "Fields & Properties"
    Private m_ctrDefs As ControlDefinitions
    Private m_ctrDef As ControlDefinition
    Private m_doc As Document
    Private m_VaultAddin As Boolean = False
#End Region
#Region "Konstruktor"
    Public Sub New(oDoc As Document)
        m_doc = oDoc
        m_ctrDefs = InventorApp.CommandManager.ControlDefinitions
        If InventorApp.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}").Activated Then
            m_VaultAddin = True
    End Sub
#End Region
#Region "Vault Commands"
    Public Sub Vault_Check_In()
        If m_VaultAddin Then
            'Einchecken aktuelles Dokument
            m_doc.Save()
            m_ctrDef = m_ctrDefs.Item("VaultCheckinTop")
            If Not m_ctrDef Is Nothing Then
                m_ctrDef.Execute()
    End Sub
    Public Sub Vault_Check_Out()
            'Auschecken aktuelles Dokument
            m_ctrDef = m_ctrDefs.Item("VaultCheckoutTop")
                m_ctrDef.Execute()
    End Sub
    Sub Vault_Get_Latest()
            'Ruft letzte Version ab
            m_ctrDef = m_ctrDefs.Item("VaultGetLatest")
                m_ctrDef.Execute()
    End Sub
    Sub Vault_Refresh()
            'Dokument aktualisieren
            m_ctrDef = m_ctrDefs.Item("VaultRefresh")
                m_ctrDef.Execute()
    End Sub
    Sub Vault_Launch_Explorer()
            m_ctrDef = m_ctrDefs.Item("VaultLaunchVaultExplorer")
                m_ctrDef.Execute()
    End Sub
#End Region
End Class
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
