Hatch scale
Hatch scale
kresh.bell
Message 1 of 9
Hatch scale
kresh.bell
is it possible to create an iLogic that could change the hatch scale for all hatch in that view in the drawing environment, with the possibility of selecting several predefined values, for example 0.05, 0.1, 1, ...
Replies (8)
Message 2 of 9
JelteDeJong
If i understand you correct then what you want can be done with standard inventor functionality.
first create all hatch styles that you want.
then in your drawing select some thing that is hatched. and select the style that you want.
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 9
WCrihfield
How about this:
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim oScales As New List(Of Double)
oScales.Add(0.05)
oScales.Add(0.1)
oScales.Add(1)
oScales.Add(1.25)
oScales.Add(1.5)
oScales.Add(2)
Dim oScale As Double = InputListBox("Select Scale.",oScales)
Dim oDSketch As DrawingSketch = oSheet.Sketches.Item(1)
oDSketch.Edit
For Each oHatch As SketchHatchRegion In oDSketch.SketchHatchRegions
	oHatch.Scale = oScale
Next
oDSketch.ExitEdit
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 9
WCrihfield
Sorry, first post timed out with error, so it sent the post twice.
Wesley Crihfield
Message 5 of 9
kresh.bell
sometimes in one view I have really many hatches, my idea is to select the view and then the change the scale using iLogic, all the hatches at once without having to select the hatch one by one
Message 6 of 9
WCrihfield
Here's another code that allows for the view selection.
I wasn't sure if you wanted to select the view before running the rule, or if you wanted to select the view after running the rule, so I included code for both scenarios, and commented the one out.
'[for if you want to pre-select the view before running the rule
Dim oView As DrawingView
If oDDoc.SelectSet.Count = 0 Then
	MsgBox("Nothing was pre-selected. Exiting.", vbOKOnly, " ")
	Exit Sub
Else
	If oDDoc.SelectSet.Item(1).Type = ObjectTypeEnum.kDrawingViewObject Then
		oView = oDDoc.SelectSet.Item(1)
	Else
		MsgBox("The selected object is not a Drawing View object." & vbCrLf & _
		"Please Select a Drawing View Object, then run again.Exiting.", vbOKOnly, " ")
		Exit Sub
'[or for selecting the view after you run the rule
'Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View.")
'If oView Is Nothing Then
'	oAns = MsgBox("Nothing was selected. Exiting.", vbOKOnly, " ")
'	Exit Sub
'End If
oScales.Add(0.01)
oScales.Add(0.1)
oScales.Add(0.25)
oScales.Add(0.5)
oScales.Add(0.75)
oScales.Add(1)
oScales.Add(1.25)
oScales.Add(1.5)
oScales.Add(1.75)
oScales.Add(2)
oScales.Add(10)
Dim oSketch As DrawingSketch
Dim oHatch As SketchHatchRegion
If oView.Sketches.Count > 0 Then
	For Each oSketch In oView.Sketches
		oSketch.Edit
		For Each oHatch In oSketch.SketchHatchRegions
		Next
		oSketch.ExitEdit
	Next
Else
	MsgBox("There were no sketches within this view.",vbOKOnly," ")
Wesley Crihfield
Message 7 of 9
kresh.bell
probably I was not clear, if , for example, I click on detail view E,
and then run rule, this is shown to me
Message 8 of 9
WCrihfield
We might have to expand the check on the pre-selected object to include multiple compatible object types (SectionDrawingView object for example), then maybe adjust the code so it will work with any of those other object types.  I'll see what I can do tomorrow (leaving for the day right now.)
Wesley Crihfield
Message 9 of 9
J-Camper
Unfortunately the hatched regions generated by Inventor, when using section tools, are not objects accessible through API.  The method in @WCrihfield's post is only for hatched regions created in a sketch.
At this time you must manually select hatch regions and change them the way @JelteDeJong mentioned.  I usually set my selection filter to Hatch only so you can use window selections:
If you are using sketches in you drawing views to hatch, then you can use the code @WCrihfield posted, but the view selection/ Object type check could be changed as follows:
	'Setup
	Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
	'View Selection
		Dim PickThis As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select Drawing View")
		If IsNothing(PickThis) Then Exit Sub ' If nothing gets selected then we're done
		oView = PickThis
	Else
		If InStr(CType(oDDoc.SelectSet.Item(1).Type, ObjectTypeEnum).ToString, "DrawingViewObject") > 0
		Else
			Exit Sub
The "InStr" Check should pick up all types of DrawingViewObjects because they all end with the same text.
