Hardware ipt replacement
Hey friends, I got a doozy for ya. The company I work for has been using Inventor for a few years now. When I came on board, I found pretty quickly that I am by far the foremost Inventor expert this company has ever had (I was an intermediate user at best), we don't have Vault (we are now getting it after I stressed how beneficial it would be, but it's slow going), and that the workflow for several thousand design assemblies has included:
Copying everything from the reference design; this would be fine if that didn't include several .ipt files per design of things like ".25 steel washer" and ".5-13 steel hex bolt 1.5" (yes, each bolt material, length, & pitch has its own .ipt file within each design's designated folder)
Using only the hardware files copied over as needed, possibly going into other folders to find new files and copying them too, but not deleting the unused ones
Copying everything on to the next design as a reference and including more and more basic hardware .ipts with identical names that aren't even used in the assembly like dozens of vestigial tails
these hardware part files are third party bodies, I assume downloaded from McMaster. They are not custom-placed content library members and do not have any associated component authoring.
So since I obviously wasn't gonna continue doing that, I immediately set up a content center library. I wanted everything to show up on the BOM the way our shop & purchasing teams like, so I copied the base CC hardware to a custom library and messed with the family overrides until it did what I needed it to do. This library is what I've been using for months, manually replacing the hardware in the copied reference assemblies as I go. The rest of the engineering team has been continuing to bloat our shared drive with component files, but that's not my problem at the moment.
I have convinced the company to implement Vault. There are many different reasons we need it, but the one I'm most excited about is that it will put a stop to this nonsense. Unfortunately, it will do that by breaking several thousand assemblies as it will refuse to import any of those extraneous identically-named files.
Friends, how do I replace the thousands of references to separate-but-identically-named .ipt files with content center parts? Is that even the right way to go about this? I didn't realize I should've been iMating everything (like I said, intermediate), and I know my coworkers haven't been, so I begrudgingly accept that the constraints will break, and that some of the .ipts are on different axes than the CC parts, so they'll sorta be floating sideways within the assemblies, but I just want Vault to approve the assembly imports without removing all hardware references.
