GUID of Factory Design Utilities
gert-leonvanlier
gert-leonvanlier
I am looking for the GUID of Factory Design Utilities. I need to check if the current assemlby is a fatory layout for my addin, but I don't know where or how to find it. Or maybe there is another option to this check? I am open to all ideas and suggestions.
cidhelp
you can check the DocumentInterests of the assembly-document. If there is a DocumentInterest with the name 'factory.filetype.factory_layout_template' this should be a factory layout. If there is a DocumentInterest named 'factory.filetype.factory_asset' the document is an asset.
Here my VBA:
Sub CheckFactoryType()
   Dim oD As Document
   Set oD = ThisApplication.ActiveDocument
   Dim oDocInterest As DocumentInterest
   For Each oDocInterest In oD.DocumentInterests
      If Left(oDocInterest.Name, Len("factory")) = "factory" Then
         Debug.Print "This is an " & oDocInterest.Name
   Next
End Sub
gert-leonvanlier
Yes! That works! Thank you very much.
I am writing in c#. This is my code:
public bool checkFactory()
            string progId = "Inventor.Application";
            Type inventorApplicationType = Type.GetTypeFromProgID(progId);
            Inventor.Application invApp = (Inventor.Application)Marshal.GetActiveObject(progId);
            //Get the active document in Inventor
            Document oDoc = (Document)invApp.ActiveDocument;
            //string to find
            string str = "factory";
            //value to return
            bool returnValue;
            foreach (DocumentInterest oDocInterest in oDoc.DocumentInterests)
                try
                    if (oDocInterest.Name.Substring(0, str.Length) == "factory")
                        returnValue = true;
                    else
                        returnValue = false;
                catch
                return returnValue;
            return true;
