Greater than Less Than
layochim
layochim
Hello, I'm trying to create a statement for my conveyor heights.
I have two heights Infeed_End and Discharge_End.
I'm trying to write "If Discharge_End > 115 And Infeed_End < 25 Then Discharge_End = 114 And Infeed_End = 26"
I'm having no luck on this.  Can anyone help me on this?
machiel.veldkamp
The if statement cannot modify two parameters in one line.
You have to break it up like this
If (Discharge_End > 115) And (Infeed_End < 25) Then
	Discharge_End = 114
	Infeed_End  = 26
___________________________
layochim
That Worked! Thank you! Would i be able to add a third condition?  Such as the Belt Length to this statement or would i need to use a different function?
machiel.veldkamp
If ((Discharge_End > 115) And (Infeed_End < 25) ) Or (Belt_Length = 200) Then
	Discharge_End = 114
	Infeed_End  = 26
This makes it that if the Discharge_end reaches above 115 + Infeed_End is below 25 stuff will happen
OR
if the Belt_Length is the exact length of 200.
You can play with it of course.
So an if statement looks for a 'true' value to actually do stuff right?
Example:
If Statement = True
      DoStuff
End if
You can also look for an other value that, when ultimitly combines to 'true' then it will do stuff..
Below here.... 2 'trues' make one giant 'true'
If (Statement = True) AndIf (OtherStatement = True)
      DoStuff
End if
Here's some more text for you to read from microsoft.
https://learn.microsoft.com/en-us/dotnet/visual-basic/language-reference/statements/if-then-else-sta...
layochim
This is great, thank you for the explanation, very helpful!
machiel.veldkamp
You're welcome! Have fun!
