GoExcel - Retrieve one or more values from a Spreadsheet as a list
tkSHE78
tkSHE78
Does anybody know how to retrieve one or more values from a Spreadsheet as a list?
This code gets the first value: "FA87"
		GearSupport = GoExcel.FindRow("P:\Inventor_Support\Design Configurations\Screw Conveyor Components.xlsx", "Gear Support", "Size", "=", "300", "Drive End", "=", "Pull")
		GearType = GoExcel.CurrentRowValue("Gear Type")
I am looking for a method to get the match(es) as a list like this:
FA87, KA87-Pos.A, KA87-Pos.B, FA97, KA97-Pos.A, KA97-Pos.B
Thomas
Michael.Navara
There is not a direct way, because method FindRow returns single integer row index. You need to find appropriate values yourself. Here is a sample code based on your screenshot
GoExcel.Open("C:\Path\To\Screw Conveyor Components.xlsx", "Gear Support")
Dim a1 = GoExcel.CellValue("A1") 'Init excel worksheet
Dim size = "300"
Dim driveEnd = "Pull"
Dim sheetValues As Object(, ) = GoExcel.Application.ActiveSheet.UsedRange.Value2
Dim result As New List(Of String)
For row = sheetValues.GetLowerBound(0) To sheetValues.GetUpperBound(0)
	If sheetValues(row, 1).ToString() = size AndAlso sheetValues(row, 2).ToString() = driveEnd Then
		result.Add(sheetValues(row, 3))
Next
'Print result
For Each item In result
	Logger.Debug(item)
Next
tkSHE78
Hi  Michael,
For some strange reason it will not work.
The spreadsheet I am using is now attached.
Do you have time for testing with my spreadsheet?
If it works for you, then I might be doing something wrong.
/Thomas
Inventor 2022 SP5.2
Michael.Navara
You are right. If you have more than one sheet and the requested one is not the active one, the code requires small update.
Dim xlsFileName As String = "C:\Path\To\Screw Conveyor Components.xlsx"
Dim xlsSheetName As String = "Gear Support"
GoExcel.Open(xlsFileName, xlsSheetName)
Dim size = "300"
Dim sheetValues As Object(,) = GoExcel.Application.Worksheets(xlsSheetName).UsedRange.Value2
Next
'Print result
    Logger.Debug(item)
Next
tkSHE78
Thanks  Michael,
That update made the difference 🙂
/Thomas
