GoExcel: 3rd Party worksheet not found: "3rd Party:Embedding 1", Sheet: "Sheet1"
taher.basha
taher.basha
I have been facing this issue Error: GoExcel: 3rd Party worksheet not found: "3rd Party:Embedding 1", Sheet: "Sheet1"
WCrihfield
Can you explain the situation any further?  Are you using an iLogic rule (local or external), a VBA macro, or some other means, trying to access that Excel sheet by code?  Is there an Excel document embedded in the 'active' document when that code is executed?  Are there more than one thing(s) embedded in that document?
Wesley Crihfield
(Not an Autodesk Employee)
