Having all the forms independent by file type, sheet metal, part, assembly etc and have them open depending on what file is being worked on has a few drawbacks.
- This may work to a degree but may fall down when in the assembly environment where every part/ assembly document is opened in the background and will end up opening the global forms associated with them. This would get messy very quickly.
- There is other issues in that you cannot close the form via ilogic, there maybe a work around for this by editing the xml file.
- Another drawback is the file is only recognized on the file it was launched from. It needs to be reopened on each file being worked on.
Maybe other user on the customization forum have better ideas. Alot of the people are using ribbon buttons and or VBA forms as the ilogic forms lack some customization.
Attached is pictures of how I have set up a toolbox global form I use, you can create tabs which can fit alot into a small space. Global tab is rules that run across files or in both assembly and parts.
Although I have separate global forms for sheetmetal, drawing iproperties and Toolbox.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
