Getting sketch entities from a sheet matal "folded" part
isocam
isocam
Can anybody help?
I have a vba macro that can convert a "ipt" file of a "laser-cut profile" directly into a dxf file.
The code shown in the attachment works perfectly!!!!
I need to do the same thing from a "folded" (un-flatterned) sheet metal "ipt" file.
I have found this from the discussion groups to onfold a part
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oDef As ControlDefinition
Set oDef = ThisApplication.CommandManager.ControlDefinitions.​Item("PartConvertToSheetMetalCmd")
oDef.Execute
Dim oCompDef As SheetMetalComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
oCompDef.Unfold
Does anybody know how I can combine the two so that I can automatically create a dxf file directly from a un-flatterned  folded sheet metal part?
Many thanks in advance!!!
IsoCAM
YuhanZhang
If you mean to only convert a normal part to sheet metal, you can just run the below code:
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
' convert to sheet metal
oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
