Getting section direction
NachoShaw
Advisor Advisor
NachoShaw
hey
I have managed to get the section line object in code from the DrawingView to add some sketch symbols. What i cant seem to do is get which direction the section is. Is that obtainable? If not, any other solution?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
omartin
Seems like the sectioned view's camera.eye property is dependent on the section line. looks like the center point of the section line is the eye's origin point(for a complex line not sure) and then the sign of the Y position is the direction of the arrow (at least on the simple test I did). I haven't had time look into if this is always true or how the eye relates to the model orientation & drawing view orientation. You can maybe start there to see if you can find any correlation.
Was my reply Helpful ? send a Kudos or accept as solution
