Getting Mesh Face Object
dylanTEV9W
Message 1 of 8
dylanTEV9W
Hello all,
I'm trying to get access to the mesh face object or more specifically the geometry in the an imported mesh. I'm trying to build a feature that is somewhat similar to the current mesh enabler but allows for parts of a mesh to be brought in and converted to native inventor surfaces rather than the entire thing. However I'm stuck just trying to get access to the meshface object or mesh geometry. If anyone knows how to get access to these please let me know.
Thanks in advance for any help!
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@dylanTEV9W,
Can you please provide sample mesh file to investigate? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
dylanTEV9W
I should be able to provide a sample file soon. The problem isn't file dependent though it occurs with every mesh file that I've brought into Inventor so far.
Message 4 of 8
dylanTEV9W
Hmm, the site won't seem to let me upload my .obj file. But as I said earlier this doesn't seem to be file dependent so solving it for any file would solve it for all of them.
Message 5 of 8
dylanTEV9W
Here is the part file. I'm trying to trim away the outer frame, because I don't need or want that converted to a surface when I use mesh enabler.
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@dylanTEV9W,
After importing mesh feature into part, unwanted face can be deleted in part model which is explained in below help documentation.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Hoping that below help documentation also helps in mesh object.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
dylanTEV9W
'Get application information
Dim part_doc As PartDocument ' get the active part document
part_doc = _invApp.ActiveDocument 'set part_doc as the active part document
Dim active_part As PartComponentDefinition ' define the active component
active_part = part_doc.ComponentDefinition ' set the active component
Dim trans_geo As TransientGeometry 'get transient geometry from the application
trans_geo = _invApp.TransientGeometry 'set trans_geo as Transient Geometry object
Dim mesh_feature_sets As MeshFeatureSets
mesh_feature_sets = active_part.MeshFeatureSets
Dim mesh_feature_set As MeshFeatureSet
mesh_feature_set = mesh_feature_sets.Item(1)
Dim mesh_feature As MeshFeature
mesh_feature = mesh_feature_set.Item(1)
Debug.Print(mesh_feature.Name)
Dim mesh_enum As MeshFeatureEntitiesEnumerator
mesh_enum = mesh_feature.Entities()
Debug.Print(mesh_enum.Count())
Dim mesh_feature_entity As MeshFeatureEntity
mesh_feature_entity = mesh_enum.Item(1)
Dim graphics_coord_set As GraphicsCoordinateSet
graphics_coord_set = mesh_feature_entity.CoordinateSet
graphics_coord_set.Remove(graphics_coord_set.Count)
Debug.Print("done")
part_doc.Update()
part_doc.Rebuild()
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@dylanTEV9W,
There is a tool from Autodesk called "MeshMixer" (http://www.meshmixer.com/). This tool can be used to edit Mesh (.obj) file and removed all unnecessary mesh data. It keeps the part that you want import into Inventor. Then, Inventor can be used to convert required meta data into B-Rep surface.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
