Getting Excel to open
I am trying to get excel to open inside of Inventor. I stole this code from the help menu and just added my file name. However first it did not like the declare functions, so I put Private in front and that seemed to work. Now I can not figure out how to get the command button portion to work. I assume it needs some kind of End Sub to balance the code but I have no idea where to put it. When I run it I get a Compile error: Expected End Sub. Any help would be apprieciated, as I really have no idea what I am doing. Just trying to meatball my way through. Here is the code.
Thanks.
' Declare necessary API routines:
Private Declare Function FindWindow Lib "user32" Alias _
"FindWindowA" (ByVal lpClassName As String, _
ByVal lpWindowName As Long) As Long
Private Declare Function SendMessage Lib "user32" Alias _
"SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, _
ByVal wParam As Long, _
ByVal lParam As Long) As Long
Private Sub CommandButton1_Click()
Sub GetExcel()
Dim number As Object ' Variable to hold reference
' to Microsoft Excel.
Dim ExcelWasNotRunning As Boolean ' Flag for final release.
' Test to see if there is a copy of Microsoft Excel already running.
On Error Resume Next ' Defer error trapping.
' Getobject function called without the first argument returns a
' reference to an instance of the application. If the application isn't
' running, an error occurs.
Set number = GetObject(, "Excel.Application")
If Err.number <> 0 Then ExcelWasNotRunning = True
Err.Clear ' Clear Err object in case error occurred.
' Check for Microsoft Excel. If Microsoft Excel is running,
' enter it into the Running Object table.
DetectExcel
' Set the object variable to reference the file you want to see.
Set number = GetObject("u:\number.XLS")
' Show Microsoft Excel through its Application property. Then
' show the actual window containing the file using the Windows
' collection of the number object reference.
number.Application.Visible = True
number.Parent.Windows(1).Visible = True
Do manipulations of your file here.
' If this copy of Microsoft Excel was not running when you
' started, close it using the Application property's Quit method.
' Note that when you try to quit Microsoft Excel, the
' title bar blinks and a message is displayed asking if you
' want to save any loaded files.
If ExcelWasNotRunning = True Then
number.Application.Quit
Set partnumber = Nothing ' Release reference to the
' application and spreadsheet.
End Sub
Sub DetectExcel()
' Procedure dectects a running Excel and registers it.
Const WM_USER = 1024
Dim hWnd As Long
' If Excel is running this API call returns its handle.
hWnd = FindWindow("XLMAIN", 0)
If hWnd = 0 Then ' 0 means Excel not running.
Exit Sub
Else
' Excel is running so use the SendMessage API
' function to enter it in the Running Object Table.
SendMessage hWnd, WM_USER + 18, 0, 0
End Sub
Sorry, do not know why the code is all bunched up.
