Getting DrawingCurve object from dimension
akAMYTB
akAMYTB
Hi
I am trying to make Inventor tell me the length of two lines used by an angular dimension in a drawing document. Below is my code so far. How do I get the DrawingCurve obje, which I understand is used by the GeometryIntent objects which i used by the dimension. I've looked at examples where a code adds a dimension between two selected lines in a drawing view ( http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-968D16DA-408E-4ED8-A87A-EE8972C644F5 ), but I sort of need it to work the other way around, since I have the dimension.
Dim App As Application
Set App = ThisApplication
Dim DrwDoc As DrawingDocument
Set DrwDoc = App.ActiveDocument
Dim Sheet As Sheet
Set Sheet = DrwDoc.ActiveSheet
Dim DrawingDimensions As DrawingDimensions
Set DrawingDimensions = Sheet.DrawingDimensions
Dim DrawingDimension As DrawingDimension
For Each DrawingDimension In DrawingDimensions
Dim LineOne As DrawingCurve
Set LineOne = ???
Dim LineTwo As DrawingCurve
Set LineTwo = ???
Next
clutsa
This seems to be working for me.
Dim Sheet As Sheet
Set LineOne = DrawingDimension.IntentOne.Geometry.Segments(1).Parent
Set LineTwo = DrawingDimension.IntentTwo.Geometry.Segments(1).Parent
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
akAMYTB
Thanks alot. Did the trick 🙂
Cheers - Anders
