Getting an occurrence without traversing
NachoShaw
Advisor Advisor
NachoShaw
Hey
im doing a lot of assembly work and more than 50% of the operation time is consumed by traversing the assembly for documents. Is there a good to get an occurrence or document definition without needing to to the loop if i had say, a filepath, display name or partial name?
I have tried the ComponentEnumerator but that seems to the take the same amount of time as a loop. I thought i could use ItemByName but that requires the Application documents not the assembly document and the file needs to be open.
I was hoping that the enumerator would be more of a lookup and be faster unless im using it wrong..
Dim Doc as string = "C;\MyFile.ipt"
Dim oAssyDoc As AssemblyDocument = Form1.G._Invapp.ActiveDocument
Dim oCompOccEnum As ComponentOccurrencesEnumerator = oAssyDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc.ComponentDefinition)
For Each oCompOcc As ComponentOccurrence In oCompOccEnum
   If oCompOcc.Definition.Document.FullFileName = Doc Then
      oC2 = oCompOcc
      Exit For
Next
Looking for the most efficient way to enumerate an assembly to find a component without it needing to be open.
thanks
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
J-Camper
I believe "ItemByName" Property uses DisplayName and can be accessed from AssemblyDocument:
Dim aCD As AssemblyComponentDefinition
aCD.Occurrences.ItemByName("Display Name")
I'm not sure what you mean by: "[...] and the file needs to be open" You have the Assembly as ActiveDocument in your code, so it is open right?
Testing Sample:
Dim aCD As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim selecting As ComponentOccurrence = aCD.Occurrences.ItemByName("select") 'Display Name
Dim selectThis As HighlightSet = ThisApplication.ActiveDocument.CreateHighlightSet
selectThis.AddItem(selecting)
MessageBox.Show("Look At Highlighted Component", "Selection")
AllReferencedOccurrences Is going to give you a group of occurrences all using the same document [multiple instances of a document]
Let me know if this isn't working for you.
NachoShaw
Hi
Thanks for the reply. I read that ItemByName required the file you wanted to find to be already open in order to find it. I could see why when the Component collection was the application collection..
i must have missed this 🙂
much appreciated
Nacho
