GetReferenceKey
GetReferenceKey
wppdev
GetReferenceKey
wppdev
Can some one explain the key we get from GetReferenceKey method.
I am using it for component occurrence and subcomponent occurrence object and I am getting different keys for both the objects.
Can I get the component id directly from the key generated?
Thanks ,
Rajdeep
HideoYamada
Hello wppdev,
Is this meaning you want to retrieve the object from ReferenceKey?
If so, use Document.RefernceKeyManager.BindKeyToObject.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
chandra.shekar.g
Autodesk Support
Autodesk Support
@wppdev,
Hoping that suggestions in below blog link may be helpful.
https://adndevblog.typepad.com/manufacturing/2012/07/reference-keys-in-inventor.html
https://modthemachine.typepad.com/my_weblog/2015/09/understanding-reference-keys-in-inventor.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Maxim-CADman77
dear @chandra.shekar.g
Here is my attempt to start with RFs in iLogic (based on the second url you've posted):
Dim doc As Document = ThisApplication.ActiveDocument
Dim selFace As Face = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select face.")
Dim refKeyMgr As ReferenceKeyManager = doc.ReferenceKeyManager
Dim keyContext As Long = refKeyMgr.CreateKeyContext
Dim faceRefKey() As Byte
Call selFace.GetReferenceKey(faceRefKey, keyContext)
On the sample IPT attached I'm getting Error:
Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
What I'm missing?
PS: I'm using Inventor 2022.3
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
I kindly hope author of that article (@BrianEkins) can comment the mismatch issue.
adam.nagy
Autodesk Support
Autodesk Support
This issue is discussed here:
https://adndevblog.typepad.com/manufacturing/2013/07/pass-arguments-to-getreferencekey-and-bindkeyto...
You just have to initialize the Byte arrays:
 Dim faceRefKey() As Byte = New Byte() {}
Adam Nagy
Autodesk Platform Services
abdullah_elq
Attaching the full iLogic code in case anyone else finds it useful:
    ' Get the active document.
    ' Have a face and edge selected.
    ' Set a reference to the ReferenceKeyManager object.
    ' Create a key context.
    ' Get reference keys from the selected entities.
    ' Get the key context as an array of bytes and
    ' convert it to a string.
    Dim contextArray() As Byte = New Byte() {}
    Call refKeyMgr.SaveContextToArray(keyContext, contextArray)
    Dim strContext As String
    strContext = refKeyMgr.KeyToString(contextArray)
    ' Convert the reference keys to strings to make saving it easier.
    Dim strFaceKey As String
    strFaceKey = doc.ReferenceKeyManager.KeyToString(faceRefKey)
	'Display the key
	MessageBox.Show(strFaceKey)
