GetPointAtParam SketchArc Not Working!
florian_wenzel
florian_wenzel
Inventor 2022
API VB.NET VisualStudio
i try to get a Point from a GetPointAtParam.
It works Fine for Line, Spline but not for SketchArcs!
Code:
       Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
        Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        Dim oSketch As PlanarSketch = oCompDef.Sketches.Item(1)
        Dim oObjCollPoints As ObjectCollection = oTO.CreateObjectCollection
        Dim oArc As SketchArc = oSketch.SketchArcs.Item(1)
        Dim oParams As Double() = {0.1}
        Dim oDouble As Double() = {}
        oArc.Geometry.Evaluator.GetPointAtParam(oParams, oDouble)
        Dim oPoint As Point2d = oTG.CreatePoint2d(oDouble(0), oDouble(1))
        oObjCollPoints.Add(oPoint)
        MsgBox("oObjCollPoints = " & oObjCollPoints.Count)
Wrong Parameter ?
Anybody Know something?
Thanks For Any Suggestion
nmunro
It appears you are assuming the parameters for the arc run from 0 - 1.0 (looking for point 10% along the arc)? It is always better to acquire the start and end parameters for the evaluator and then use those values in your call to get the point.  Your code modified in VBA below.
    Set oPartDoc = ThisDocument
    Set oCompDef = oPartDoc.ComponentDefinition
    Set oTO = ThisApplication.TransientObjects
    Set oTG = ThisApplication.TransientGeometry
    Set oSketch = oCompDef.Sketches.Item(1)
    Set oObjCollPoints = oTO.CreateObjectCollection
    Set oArc = oSketch.SketchArcs.Item(1)
    Dim oParams(0) As Double
    Dim oDouble(1) As Double
    Dim eval As curve2devaluator
    Set eval = oArc.Geometry.Evaluator
    Dim startParam As Double
    Dim endParam As Double
    ' get start and end parameter values
    Call eval.GetParamExtents(startParam, endParam)
    ' get parameter at 10% along arc - from start
    oParams(0) = startParam + 0.1 * (endParam - startParam)
    Call eval.GetPointAtParam(oParams, oDouble)
    Set oPoint = oTG.CreatePoint2d(oDouble(0), oDouble(1))
    Call oObjCollPoints.Add(oPoint)
    MsgBox ("oObjCollPoints = " & oObjCollPoints.Count)
https://c3mcad.com
florian_wenzel
Hi @nmunro ,
Thank you for Solution.
ok, so it works.
Also, when you Project this Arc2D to Sketch3D, and then with CurveEvaluator for 3D The Method GetPointatParam  Works fine.
But as you show, for Arc2D works also.
Thanks.
