GetObject(, "Excel.Application") takes forever, sometimes
bwangNYAKX
bwangNYAKX
Hi all,
I am writing a code that needs to extract some value from excel. My code worked fine but today all in a sudden when I run it, the code started to get stucked in getobject function forever. No any error, it just seems to me that the code is running something countless times...  This happened me two days ago but all in a sudden it was gone. Now it came back. What can I do?     FYI, 1. CreateObject("Excel.Application") works fine, just takes so long
Dim oexcelApp As Object
                       On Error Resume Next
                                       Set oexcelApp = GetObject(, "Excel.Application")
                                     If Err Then
        Err.Clear
        Set oexcelApp = CreateObject("Excel.Application")
        If Err Then
        MsgBox "Cannot access excel."
        Exit Sub
robertast
In the 2021.1 update, they promised to improve communication with Excel. The beta version has already appeared in skaro and will be available publicly.
sgodonVEAP9
I have the exact same problem here.. I have this very simple code that copies excel values:
Dim xlApp
Set xlApp = GetObject("", "Excel.Application")
Dim xlWorkbook As Object
Set xlWorkbook = x1App.Workbooks.Open("C:\Users\ac rainville\Desktop\TEST\SHUMAKER.xlsm")
With xlWorkbook.Worksheets(3)
.Range("A1:F77").Copy
End With
It takes around 10 to 12 seconds only to run this.. Any ideas how to improve that? thanks!
A.Acheson
I tested this and it should be in the region of 1.8secs to open visible the excel sheet and select the cells. Your code has an error on this line “x1App.Workbooks.Open” for some reason the “l” is actually the number “1”
As for slow opening, try and open excel manually and see if it opens quickly. If you have a lot of templates/files opening on startup this morning guy be a reason. After that check off any addins in the excel application, one of them could be causing a delay, I have found the 3D mouse was at fault causing slow start up speed.
Regards
Alan
