GetMinimumDistance returning wrong value
GeorgK
Advisor Advisor
Message 1 of 8
GeorgK
Hello together,
I try to get the minimaldistance with this code:
m_invApp = GetObject(, "Inventor.Application")
        Dim oFaceProxy As FaceProxy
        oFaceProxy = m_invApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face")
        If oFaceProxy Is Nothing Then
            Exit Sub
        On Error GoTo 0
        Dim oAssyDoc As AssemblyDocument
        oAssyDoc = m_invApp.ActiveDocument
        ' Set a reference to the mass properties object.
        Dim oMassProps As MassProperties
        oMassProps = oAssyDoc.ComponentDefinition.MassProperties
        'Check if mass property results are already available
        'at a high accuracy level or better. If so, simply
        'print out the results, else, set a flag to not cache
        'the results in the document.
        If oMassProps.AvailableAccuracy = MassPropertiesAccuracyEnum.k_High And oMassProps.AvailableAccuracy = MassPropertiesAccuracyEnum.k_VeryHigh Then
            ' Set the accuracy to high.
            oMassProps.Accuracy = MassPropertiesAccuracyEnum.k_High
            'Set CacheResultsOnCompute property to False
            'so that results are not saved with the document
            'and hence the document is not 'dirtied'.
            oMassProps.CacheResultsOnCompute = False
        Dim oMeasureTools As MeasureTools
        oMeasureTools = m_invApp.MeasureTools
        Dim oDistance As Double = oMeasureTools.GetMinimumDistance(oMassProps.CenterOfMass, oFaceProxy.PointOnFace)
        oDistance = oAssyDoc.UnitsOfMeasure.ConvertUnits(oDistance, "cm", "mm")
        MsgBox(oDistance)
But the result is wrong.
What I am doing wrong?
Thank you
Georg
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Code seems to fine for me. Can you please demonstrate wrong distance value? I mean, what is actual value and expected value from Inventor API.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
GeorgK
Hello @chandra.shekar.g,
there is a difference:
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please provide sample file to test this behaviour? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
GeorgK
Attached is a sample model
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Tried below VBA code to measure distance between center of mass and selected face.
Sub Distance()
    Dim oFace As FaceProxy
    Set oFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a face")
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oMassProp As MassProperties
    Set oMassProp = oDef.MassProperties
    Dim oWpt As WorkPoint
    Set oWpt = oDef.WorkPoints.AddFixed(oMassProp.CenterOfMass)
    Dim oTool As MeasureTools
    Set oTool = ThisApplication.MeasureTools
    Dim oDist As Double
    oDist = oTool.GetMinimumDistance(oWpt, oFace)
    oDist = oDoc.UnitsOfMeasure.ConvertUnits(oDist, "cm", "mm")
    MsgBox (oDist)
End Sub
On running above code, it prompts for selection of face and selected the face as shown below.
On successful completion of code, Distance is shown in message box as shown below.
Which is same value as measured in Measure tool.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
GeorgK
thank you very much. That's working but without the
 Is there any solution for this? Or is the result buggy?
Georg
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Same result is shown after using "CacheResultsOnCompute" property. Try below VBA code.
Sub Distance()
    If oMassProp.AvailableAccuracy = k_High Or oMassProp.AvailableAccuracy = k_VeryHigh Then
        oMassProp.Accuracy = k_High
        oMassProp.CacheResultsOnCompute = False
    Dim oDist As Double
    oDist = oTool.GetMinimumDistance(oMassProp.CenterOfMass, oFace)
    MsgBox (oDist)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
