GetDWGDocumentReferences with bug?
mikazakov
Message 1 of 1
mikazakov
I tried use GetDWGDocumentReferences for part with import acad. But GetDWGDocumentReferences return exception.
File attached for test. Its bug?
Any ideas?
 Sub Main()
        Dim InvApp As Application = GetInventorApplication()
        Dim FM As FileManager = InvApp.FileManager
        Dim TestFile As String = "D:\Part10.ipt"
        Dim str() As String = FM.GetDWGDocumentReferences(TestFile)
        Console.ReadKey()
    End Sub
    'Функция получения ссылки на Inventor
    Function GetInventorApplication() As Application
        Try
            'Попытка присоединится к загруженному в память Inventor
            InvApp = CType(Marshal.GetActiveObject("Inventor.Application"), Application)
        Catch ex As Exception
            'Загрузка Inventor в память и присоединение к нему
            Dim InvType As Type = Type.GetTypeFromProgID("Inventor.Application")
            InvApp = CType(Activator.CreateInstance(InvType), Application)
            InvApp.Visible = True
        End Try
        Return InvApp
    End Function
Replies (0)
