Get UCS workpoint co-ordinates
Saikiran_arakeri
Message 1 of 14
Saikiran_arakeri
Hey guys I am trying to extract these co-ordinates of the workpoint.
Selection 1 was the co-ordinate system you see on the right side marked in black associated with the part, selection 2 was the assembly co-ordinate system. I am trying to extract the X,Y & Z values highlighted in red. @WCrihfield @Andrii_Humeniuk @A.Acheson @JelteDeJong
Replies (13)
Message 2 of 14
WCrihfield
Running short on time, but here is a good link to look into.  It explains how the ThisApplication.MeasureTools.GetMinimumDistance method works.  It can be much more complex than most folks normally make use of.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 14
Saikiran_arakeri
Hey @WCrihfield that's okay. It can wait till Monday, let's see if we can find out a solution.
Message 4 of 14
JelteDeJong
Using the measureTools might be the best option. But there is also the option to calculate the distance yourself. Here is my two-penny worth.
It was not clear to me if you wanted to measure from an occurrence UCS to some custom UCS or between 2 UCSs. Anyway here 2 examples
occurrence -> UCS
Dim occ As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Occurrence")
Dim ucs2 As UserCoordinateSystem = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kUserCoordinateSystemFilter, "Select UCS 2")
Dim position1 = occ.Transformation.Translation
Dim position2 = ucs2.Definition.Transformation.Translation
Dim diffX = (position2.X - position1.X) ^ 2
Dim diffY = (position2.Y - position1.Y) ^ 2
Dim diffZ = (position2.Z - position1.Z) ^ 2
Dim distance = Math.Sqrt(diffX + diffY + diffZ)
MsgBox(distance & " Cm")
 UCS -> UCS
Dim ucs1 As UserCoordinateSystem = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kUserCoordinateSystemFilter, "Select UCS 1")
Dim position1 = ucs1.Definition.Transformation.Translation
Jelte de Jong
Blog: hjalte.nl - github.com
Message 5 of 14
Saikiran_arakeri
So, UCS1 is in the assembly component definition and UCS2 is in the component occurrence definition. When I used the code @JelteDeJong gave, I am getting the difference as 0,0,0. I think this is because UCS1 is created at 0,0,0 in the assembly and UCS2 is created at 0,0,0 in the ComponentOccurrence. Correct me if I am wrong.
I am trying to hence get the workpoint X,Y & Z values like shown in the picture so that I can get precise co-ordinates.
Message 6 of 14
JhoelForshav
Hi @Saikiran_arakeri
Try this example. This code lets you pick the two coordinatesystems you want and then we use the transient geometry of the centerpoints of these coordinate systems to measure the distance and the differences in x, y, z.
I'm also using units of measure to convert to the units your'e using in Inventor.
Dim centerPoint1 As Point = ucs1.Origin.Point
Dim centerPoint2 As Point = ucs2.Origin.Point
Dim UoM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Dim retString As String = "Distance: " & UoM.ConvertUnits(centerPoint1.DistanceTo(centerPoint2), UnitsTypeEnum.kDatabaseLengthUnits, _
UnitsTypeEnum.kDefaultDisplayLengthUnits) & UoM.GetStringFromType(UnitsTypeEnum.kDefaultDisplayLengthUnits) & vbCrLf
Dim deltaX As Double = centerPoint1.X - centerPoint2.X
Dim deltaY As Double = centerPoint1.Y - centerPoint2.Y
Dim deltaZ As Double = centerPoint1.Z - centerPoint2.Z
retString += vbCrLf & "Delta X: " & UoM.ConvertUnits(deltaX, UnitsTypeEnum.kDatabaseLengthUnits, _
retString += vbCrLf & "Delta Y: " & UoM.ConvertUnits(deltaY, UnitsTypeEnum.kDatabaseLengthUnits, _
retString += vbCrLf & "Delta Z: " & UoM.ConvertUnits(deltaZ, UnitsTypeEnum.kDatabaseLengthUnits, _
MsgBox(retString)
Message 7 of 14
WCrihfield
If the position of the first UCS will always be the same as the main assembly's own origin, and already aligned with the main assembly's origin work features, that would certainly simplify the task a bit...eliminating the need for the first Pick function, and eliminating the need for the 'difference' type math.  And if the second UCS will always be within a component, you would just need to get the top level proxy of that second UCS (which will be in the context of the main assembly), then get its origin coordinates,  which will already be relative to the main assembly's origin.  And if always using the Pick function to get that second UCS, you will already have the top level proxy of it.  The only thing left to do is maybe convert the units, if needed, which Jhoel showed how to do in his example.
Wesley Crihfield
Message 8 of 14
Saikiran_arakeri
Thanks @JhoelForshav , this worked perfectly fine.
Message 9 of 14
Saikiran_arakeri
Hey @WCrihfield @JhoelForshav
I am trying to get UCS2 without using the Select function, how do I do that?
Message 10 of 14
WCrihfield
Example:
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
'get UCS in main assembly named "Global"
Dim oGlobalUCS As UserCoordinateSystem = oADef.UserCoordinateSystems.Item("Global")
'get component named "Part2"
Dim oP2 As ComponentOccurrence = oADef.Occurrences.ItemByName("Part2")
'get UCS in Part2, named "UCS2"
Dim oP2_UCS As UserCoordinateSystem = oP2.Definition.UserCoordinateSystems.Item("UCS2")
'get the proxy of that UCS, so it is in the context of the main assembly
Dim oP2_UCSProxy As UserCoordinateSystemProxy = Nothing
oP2.CreateGeometryProxy(oP2_UCS, oP2_UCSProxy)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
Message 11 of 14
Saikiran_arakeri
Hey @WCrihfield Line 8, the property Usercoordinatesystems isn't available in Occurrence.Definition
Message 12 of 14
Saikiran_arakeri
Instead of trying to find Usercoordinatesystems in Occurrence.Definiton, I type casted the Occurrence into Partdocument, went for the Part document Component Definition and accessed the Usercoordinatesystems there and created a proxy. It worked perfectly fine @WCrihfield Thank you
Message 13 of 14
Saikiran_arakeri
Thanks @JhoelForshav @WCrihfield @JelteDeJong, I have understood so much doing this project with your constant help and guidance.
Message 14 of 14
WCrihfield
That is true from an Intellisense (the pop-up suggestions system) point of view, because a generic ComponentDefinition object does not have that property, but the more specific types of a ComponentDefinition, such as a PartComponentDefinition or AssemblyComponentDefinition do have that property, so it should still work, even if Intellisense does not show it as being available.  If it would make more sense, the code could be broken down into more lines of code, where we create a variable of the more specific type, then set its value using the ComponentOccurrence.Definition.  Then move forward using that more specific type of variable, that way the Intellisense will show it as available.
Dim oP2Def As PartComponentDefinition = oP2.Definition
Dim oP2_UCS As UserCoordinateSystem = oP2Def.UserCoordinateSystems.Item("UCS2")
Wesley Crihfield
