Get the quantity using ILogic code
FINET_Laurent
Advisor Advisor
FINET_Laurent
Morning everyone.
I whould like to know if it is possible to get the quantity of a part and set this quantity as a double using ilogic in an assembly. (not a custom iproperty)
I'm talking about the part quantity shown in the default BOM. 😥
Thanks and best regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
JhoelForshav
Hi @FINET_Laurent
Try this:
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oBOM As BOM = oAsm.ComponentDefinition.BOM
Dim oBomView As BOMView = oBOM.BOMViews(1)
Dim oBomRows As BOMRowsEnumerator = oBomView.BOMRows
Dim oBomRow As BOMRow
Dim oDef As ComponentDefinition
For Each oBomRow In oBomRows
	Try
		If oBomRow.ComponentDefinitions(1).Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "Part number here"
			oBomRow.TotalQuantity = 80 'Quantity
	Catch
	End Try
Next
Just fill in your parts part number and the quantity you want.
Daan_M
You can try something like this
iLogicVb.UpdateWhenDone = True
Dim PartQuantity As Double = 0
Dim test As String
For Each oRefDoc As Document In oAsm.AllReferencedDocuments
	If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso _
		oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count > 0 AndAlso
		oRefDoc.DisplayName = "Part or member name of part document"
		PartQuantity = PartQuantity + 1
		On Error Resume Next
	Next
	MsgBox(PartQuantity) 'do something with the quantity here
JhoelForshav
Oh I get it now I think... You just want to store the value in a double? Since it's not a decimal value, I'd suggest an Integer instead.
Just count the referenced occurrences of the part in the assembly:
Dim oAsm = ThisDoc.Document
Dim oPartOcc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Pick part")
Dim oPart As PartDocument = oPartOcc.Definition.Document
Dim oQty As Integer = oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oPart).Count
MsgBox(oQty)
FINET_Laurent
First of all thank you, it works perfectly as intended but I have an other question.
Is it possible to target the part name using a string (part1.ipt)  instead of clicking the actual part.
Thanks and have a nice day,
FINET L.
JhoelForshav
@FINET_Laurent
Something like this maybe? 🙂
Dim partName As String = "Part1.ipt"
Dim oQty As Integer = 0
If oRefDoc.FullFileName.EndsWith(partName)
oQty = oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count
Exit For
Next
MsgBox(oQty)
Or if you rather use displayname (no file extension)
Dim partName As String = "Part1"
If oRefDoc.DisplayName = partName
Exit For
Next
MsgBox(oQty)
FINET_Laurent
This is exactly what I needed !
Thank you for sharing knowledge ! 🙂
Have a nice day,
FINET L.
