get save date
get save date
martinhoos
Message 1 of 12
get save date
martinhoos
i like to show via "MessageBox.Show" the date of cell H3 (Excel).
If i go with this code:
myCell = GoExcel.CellValue(myXLS, "Sheet1", "H3")
MessageBox.Show("the date:" & " " & myCell,"iLogic")
i get the result: 42957  instead of 14.08.2017.  This wont work!
Is it possible, Instead of the above code, to show the savedate of the Excel file with the right date 14.08.2017?
Thanks for your help.
Regards Martin
Replies (11)
Message 2 of 12
b_sharanraj
hi @martinhoos
Change the Format of H3 Cell from Date to General in Excel and try once 🙂
Regards
B.Sharan Raj
Message 3 of 12
martinhoos
Hi Sharan,
thank you for your reply... thats too easy - the Excel file is generated by an automatic process. Change this cell by hand runs out of the routine/code.
All changes or input should come out of the code.
Regards Martin
Message 4 of 12
b_sharanraj
Is Excel generated by Inventor or some other Excel via Macros or External Apps?
Is H3 Cell is formula like "=Today() " or Value like 14.08.2017?
Regards
B.Sharan Raj
Message 5 of 12
martinhoos
Hi Sharan,
thx for reply. The file is generated via external app. The format is like:  14.08.2017
Regards Martin
Message 6 of 12
What is the format of the cell in excel? Is the entry in cell H3 exactly written as 14.08.2017  ???
I did a quick test and it returns exactly as it is in excel
Message 7 of 12
martinhoos
Hi Craig,
thx for your reply. Pls look at the pic.
Regards Martin
Message 8 of 12
I don't have the same options as you do in my excel cel format (see attachment). But this is the code I tried and I attached a picture of the resulting msg box
myCell = GoExcel.CellValue(myXLS, "Sheet1", "A1")
MessageBox.Show(myCell, "Title")
What version of excel are you using? Perhaps try this line instead:
Dim myCell As Date = GoExcel.CellValue(myXLS, "Sheet1", "A1")
Message 9 of 12
b_sharanraj
Hi Martin
You need to try once what Mr.Henderson suggested still if it's not working we have to Change the Format Data of the cell while it's generating from your External App
Regards
B.Sharan Raj
Message 10 of 12
martinhoos
Hi Craig,
the result of the first solution:  42961
If i try
i get an error:
I use Excel 2010
Thx for your help!
Regards Martin
Message 11 of 12
b_sharanraj
Hi @martinhoos
Try this
myCell = DateTime.FromOADate(GoExcel.CellValue(myXLS, "Sheet1", "A1"))
Regards
B.Sharan Raj
Message 12 of 12
martinhoos
Hello Sharan,
thats it! Your code works...
Thank you very much...
Regards Martin
