Get partnumbers of purchased parts, excluding pp in purchased assy's
hldr
hldr
Hi all,
I'm working on an iLogic rule which will export certain part numbers to a txt-file. I want to export all part numbers of parts and sub assemblies that are set as purchased. Sometimes a purchased subassy contains some purchased parts, but i don't need the part numbers of those parts.
So basically i need an export of all the partnumbers  that would show op as purchased in the parts-only BOM.
The rule is mostly working, but the part that should skip purchased parts in purchased assy's seems to be causing problems. So I was wondering if there is a better/alternative way to write this:
If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Or oRefDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Or oRefDoc.SubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Or oRefDoc.SubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then
				Dim oPartDoc As Document
				oPartDoc = oRefDoc
				'Check if part is purchased part
				If oPartDoc.ComponentDefinition.BOMStructure = 51973 Then 'Purchase
					Dim oRefAssys As DocumentsEnumerator = oRefDoc.ReferencingDocuments
					Dim PurchaseCheck As Document
					Dim ReffPurchasePart As Boolean
					ReffPurchasePart = True
				'Check if there are purchased parts in purchased assy's, if so then ignore these parts
					For Each PurchaseCheck In oRefAssys						'purchase						'assembly
						If PurchaseCheck.ComponentDefinition.BOMStructure = 51973 And PurchaseCheck.SubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Then
							ReffPurchasePart = False
						End If																								'weldment
						If PurchaseCheck.ComponentDefinition.BOMStructure = 51973 And PurchaseCheck.SubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then
					Next
					If ReffPurchasePart = False Then
					Else
A.Acheson
Perhaps an easier way is to work directly with the BOM and select the parts only tab then loop through the BOM checking and adding the purchased parts/assemblies to a list. API sample here
Dim PurchasedList As New ArrayList
Dim AssyDoc As AssemblyDocument
AssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = AssyDoc.ComponentDefinition
Dim oBOMView As BOMView
oBOMView = oAsmCompDef.BOM.BOMViews("Parts Only")
For Each oBOMRow As BOMRow In oBOMView.BOMRows
	Dim oDoc As Document = oBOMRow.ComponentDefinitions.Item(1).Document
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Or oDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Or oDoc.SubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Or oDoc.SubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then
		If oDoc.ComponentDefinition.BOMStructure = 51973 Then 'Purchase
			'Logger.Info(oDoc.DisplayName)
			Dim oDTP As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
			Dim oPN As String = oDTP.Item("Part Number").Value.ToString
			PurchasedList.Add(oPN)
Next
d0 = InputListBox("Prompt", PurchasedList, d0, Title := "Purchased List", ListName := "List")
Regards
Alan
hldr
Thank you for your reply. I just bumped on some other practical purchased parts problems, and decided to use a completely different approach. Thank you anyway!
