Get overall dimensions of all views of a drawing by iLogic
Jakob_Hamburg
Jakob_Hamburg
Hello.
I have a drawing with many different single parts on. I want to get the overall dimensions (height and width) automatically on all base views.
There is a rule written by "Jelte de Jong" which generates the overall dimensions (height and width) on a view that you as a user have to pick. (http://www.hjalte.nl/37-auto-overall-dimension)
I wanted my rule to iterate to all views and generate the overall dimensions.
But I cannot get the rule running. I get an error message "Object reference not set to an instance of an object."
Can anyone please help me?
Public Class ThisRule
' This code was inspired and uses much of a code by Jelte de Jong
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
Sub main
' Check a document is open
If ThisApplication.Documents.VisibleDocuments.Count = 0 Then
	MessageBox.Show("A Drawing Document needs to be open")
	Exit Sub
' Check active document
If ThisApplication.ActiveDocumentType <> Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
	Exit Sub
' Get the active document
'Dim oDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
_doc = ThisDoc.Document
' Iterate through all sheets
For Each _sheet As Inventor.Sheet In _doc.Sheets
	' Iterate through all views
	For Each _view As Inventor.DrawingView In _sheet.DrawingViews
		' Check view is a base view, skip if not
		If _view.ViewType <> Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then Continue For
		    CreateIntentList()
      		createHorizontalOuterDimension()
        	createVerticalOuterDimension()
	Next ' Next view
Next ' Next sheet
End Sub
'Public Class ThisRule
'	' This code was written by Jelte de Jong
'	' and published on www.hjalte.nl
'    Private _doc As DrawingDocument
'    Private _sheet As Sheet
'    Private _view As DrawingView
'    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
'    Sub Main()
'        _doc = ThisDoc.Document
'        _sheet = _doc.ActiveSheet
'        _view = ThisApplication.CommandManager.Pick(
'                       SelectionFilterEnum.kDrawingViewFilter,
'                       "Select a drawing view")
'        CreateIntentList()
'        createHorizontalOuterDimension()
'        createVerticalOuterDimension()
'    End Sub
    Private Sub createHorizontalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
        Dim pointLeft = orderedIntents.First
        Dim pointRight = orderedIntents.Last
        Dim textX = pointLeft.PointOnSheet.X +
                (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
        Dim textY = _view.Position.Y - _view.Height / 2 - 2
        Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
    Private Sub createVerticalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim pointLeft = orderedIntents.Last
        Dim pointRight = orderedIntents.First
        Dim textY = pointLeft.PointOnSheet.Y +
                (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
        Dim textX = _view.Position.X + _view.Width / 2 + 2
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
    End Sub
    Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
        Else
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
    Private Sub CreateIntentList()
        For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
            Select Case oDrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
End Class
JelteDeJong
You can try it like this:
    Sub Main()
		For Each sheet As Sheet In _doc.Sheets
            For Each view As DrawingView In Sheet.DrawingViews
                If (view.ViewType <> DrawingViewTypeEnum.kStandardDrawingViewType) Then Continue For
				_sheet = Sheet
				_view = View
				CreateIntentList()
            Next
        Next
    End Sub
        Dim textY = _view.Position.Y + _view.Height / 2 + 2
    End Sub
        Dim textX = _view.Position.X - _view.Width / 2 - 2
    End Sub
        If onLineCheck Then
        Else
    End Sub
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Return False
        End Try
        Return True
    End Function
                Case _
                Case _
                Case _
                Case Else
            End Select
        Next
    End Sub
    ' Copyright 2021
    ' This code was written by Jelte de Jong, and published on www.hjalte.nl
    ' Permission Is hereby granted, free of charge, to any person obtaining a copy of this
    ' software And associated documentation files (the "Software"), to deal in the Software
    ' without restriction, including without limitation the rights to use, copy, modify, merge,
    ' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons
    ' to whom the Software Is furnished to do so, subject to the following conditions:
    ' The above copyright notice And this permission notice shall be included In all copies Or
    ' substantial portions Of the Software.
    ' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED,
    ' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR
    ' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE
    ' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or
    ' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER
    ' DEALINGS In THE SOFTWARE.
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Jakob_Hamburg
Hi Jelte,
thank you for the answer.
Unfortunately the code is not working well.
The code generates the overall dimensions for the first view, but then it stops and gives an error message.
"The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
So it just generates the overall dimensions on the first view, but when it wants to continue on the next view there comes an error.
Maybe some variables have to be reset but I cannot figure it out.
JelteDeJong
You are right, I did test the code only on a drawing with 1 view.... The variable "_intents" needs a reset for each view. try it like this:
    Sub Main()
                If (View.ViewType <> DrawingViewTypeEnum.kStandardDrawingViewType) Then Continue For
				_intents = New List(Of GeometryIntent)()
				_sheet = Sheet
				_view = View
				CreateIntentList()
            Next
        Next
    End Sub
    End Sub
    End Sub
        If onLineCheck Then
        Else
    End Sub
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Return False
        End Try
        Return True
    End Function
                Case _
                Case _
                Case _
                Case Else
            End Select
        Next
    End Sub
    ' Copyright 2021
End Class
Jelte de Jong
Jakob_Hamburg
Perfect, it is working.
Thank you so much.
